2025 Chinese Grand Prix [Shanghai] March 21-23
Mogster
Re: 2025 Chinese Grand Prix [Shanghai] March 21-23
basti313 wrote:
23 Mar 2025, 15:14
Mogster wrote:
23 Mar 2025, 15:00
bauc wrote:
23 Mar 2025, 12:46
Refueling strategies eventually converge and they are super predictable after that point, especially with one tire supplier in place.
Refuelling was racing cancer in F1. After a couple of years the teams used fuel stops to keep the cars apart on track. As a viewer you had no idea what was going on, no one outside the teams was aware of how much fuel was onboard each car. Even the teams felt it was a boring way to go racing.
I do fell pit stops take too long and restrict strategy too much. Increasing the pit lane speed limit seems unlikely, although I don’t see it being a problem at circuits with wide pit lanes. New circuits could be designed so the pit lane exit formed a short cut, maybe some existing ones could be modified. That way you could reduce the pit delta to 10 seconds or so. That would enable more strategies and stop the leaders driving slowly in worn tyres as we saw today.
I think this is the point, pitting takes to long. I do not think they rise the pit speed limit, but I like the point on track rework.
They could easily pave most of the gravel trap here in China, keeping the outside gravel for the last corner, but making the entry to the pit lane a fast corner with the old layout being a big runout. This would remove several seconds without compromising security. If they want to take it really serious...put the pit entry on the long straight, I think there is nothing in the way. With a nice extra corner they could tune pit delta to 15sec.
Same goes with other tracks. In Bahrain for example they could just go into the Oval for the pit entry and shorten the track by even up to 10sec. There is noting in the way.
Yes. The early concept proposed Hanoi circuit was clearly designed with a short pit delta in mind. The final draft had a more conventional layout due to local on the ground issues iirc.
TFSA
101FlyingDutchman wrote:
23 Mar 2025, 14:23
I hope they bring in a rule of having to use soft/medium/hard in every race as the default.
I've said it before and I'll say it again: This is probably the absolutely worst thing they could do. You've just removed all strategy from any dry race there is.
If a race under normal cumstances could be completed on a 1 stopper, then every team would converge on the same cookie cutter strategy: Start on softs to gain as many positions as possible on launch, and then pit early into clean air (or in case of early safety car) and get rid of the softs.
It's a poorly thought out idea, and it's only gonna make things worse.
matt_b
matt_b
Great win from Oscar today closed the gap to just 10 points when it was a massive 24 points the week before, its exciting to see two team mates battle for the championship because that certainly was not happening at Red Bull when they had a dominant car.
venkyhere
venkyhere
The easiest way to remove 'luck factor' from F1 races :
1) pit lane closed during VSC.
2) pitlane closed under SC, but allow the lapped cars to go the rear of the queue, as it is today.
3) If someone has damage/puncture that can be addressed in the pitlane, allow them to pit under SC/VSC but they have to go to the back of the queue after repair ; won't be allowed to come out of the pitlane as they please.
That way, no one gets a 'free' pitstop. No need to do anything else.
basti313
basti313
matt_b wrote:
23 Mar 2025, 17:04
Well, let us hope it is similarly to RedBull only one year they fight with themselves...
Don`t russel the hamster!
kurtj
kurtj
matt_b wrote:
23 Mar 2025, 17:04
That reminds me of Bottas' and Perez's early season performances that gave a sense that there could be team mate fight when their respective cars were dominant. Only for the lead driver of the team pull ahead as the season peaks. If Lando belongs to elite category, he would do what Max and Lewis used to do as the season progressed. Otherwise, we may have a team mates fight. Lando messed up in Q3 runs, which has been a pattern for him. On the upside for him, he is not bottling his race starts of late. We will see if the fight continues as season progresses and drivers get better understanding of the cars.
If Pirelli goes conservative with tires and pressures, we may see more aggressive racing. They raced today with a likely all time high tire pressure of 27.5 psi. I don't remember pressures being that high while tires choice being aggressive.
Mogster
TFSA wrote:
23 Mar 2025, 15:49
23 Mar 2025, 14:23
Qatar 2023 we had additional mandatory stops and it didn’t improve things.
chrisc90
Mogster wrote:
23 Mar 2025, 19:08
TFSA wrote:
23 Mar 2025, 15:49
23 Mar 2025, 14:23
That was because Pirelli put a maximum number of laps on the tyres with no scope for change. It was a case of 18 laps on these tyres, then 15 on that set.
_cerber1
266
Vettel165 wrote:
23 Mar 2025, 13:06
They should look at that Mclaren also. ;)
I hope this makes you feel better.
chrisc90
_cerber1 wrote:
23 Mar 2025, 19:50
Vettel165 wrote:
23 Mar 2025, 13:06
Doesn’t mean that all the tests were done on the mclarens. They pick random cars for a series of tests, not all of them.
Kiril Varbanov
147
My goodness, being a Ferrari fan requires a lot of patience and makes you wonder how an allegedly top 3 team can make such silly mistakes.
At this point it is clear to me that Mclaren are out of reach for both Mercedes and Red Bull, so the fight for places 2 to 4 is going to be rather interesting.
On the other hand, overregulated F1 makes another run at my nerves.
Maybe they can limit the number of times the drivers:
1. wave at fans
2. use the radio
3. make steering wheel adjustments during the race
4. use the liquid...
Doppio zero.
Shrieker
venkyhere wrote:
23 Mar 2025, 17:07
Fully concurred.
-Atatürk
TeamKoolGreen
TeamKoolGreen
-5
F1NAC wrote:
23 Mar 2025, 10:38
Antonelli driver of the day?? What?
The fangirls took control of the vote. He's a hansom young Italian
zeph
zeph
venkyhere wrote:
23 Mar 2025, 17:07
I like the way you think. I'd go one step further, discontinue the VSC altogether, and no un-lapping under the SC. But I would also restrict SC deployment.
Artur Craft
40
Hoffman900 wrote:
23 Mar 2025, 14:04
Furthermore, the cars today are 200kg heavier, add fuel and it’s near 300kg, with about the same peak power as then. All because rules. That’s not the tires’ fault.
The tires absolutely were for Schumacher and the Ferrari. I even remember Max Mosley making a big stink about it.
The cars finish the race on light fuel, you know? :roll: Hamilton had fresh tyres and low fuel(like 2004) for his last stint and what was his pace? 3s slower than the 2004 race record. All that on a fresh tarmac which offers much more grip. The only advantage of the 2004 cars was the 200kg less weight. They had 900HP back them and now 1k, the difference in torque is even bigger. Cars are wider(wider track spreads the load more across both sides yielding more grip from the tyres. That alone was estimated by engineers to slow the 1998 cars by 1.5s cars compared to the 1997 ones). In 2004 they used slim grooved tyres that could be pushed to hell throughout all the stint, no management. Needless to mention the difference in downforce.....
It´s funny that you brought the bike comparison, I won´t talk about it because I don´t follow WSBK at all and only watch MotoGP for fun without focusing on technical details. But I can do some rough estimations for F1, if you will. The difference in weight from 600 to 800kg account for some 8s(some 0.4s per 10kg and it gets lower as the weight increases. From 800 to 810, for instance, it´s around 0.35s on an average track, IIRC). When, in 2009, we went from grooved to slicks (same width), Bridgestone said the gain was around 2.5s. The gap from a grooved slim tyre to a very wide slick one should be closer to 4s, at least. As I said, the 2m car track vs the 1.8m one account for some 1.5s. The aero and Power/Torque difference is quite harder to quantify but so far, accounting only for the other factors, 2004 should be just 2.5s faster. The actual gap is already greater than that :lol: I won´t factor in the new tarmac(which could impact on several seconds(remember the 3s improvement on Sepang on 2016?), because in 2004 they also had a new one, even if today´s might be better. With much more downforce and Power/Torque, these cars should be a bit faster, not almost 3s slower than 2004 as most of the ~8s weight gap is counterbalanced by wider track and much wider slicks.
These are just rough estimates, because as I´m not an insider, I can´t give you precise data but considering that 2 decades later Bridgestone(and everybody else) tyres evolved a lot, being seemingly much slower than a 2004 tyre is humiliating. For reference, from 2014 to 2015, Michelin made a big progress with their compounds bringing tyres ~2.5s faster for about the same durability(WEC). Obviously, this doesn´t happen often and it was a huge one-off step. Just shows tyre are ever evolving.
Finally(if you have survived the long read), if Pirelli is so damn good and so capable, why don´t they go face competition on SuperGT? Even Yokohama and Sumitomo are brave enough to face Bridgestone. Also, Hypercar has open tyres reg, just like LMP1s had. Why do you think no other supplier dares to battle Michelin there? I think even Bridgestone(which is great) have nightmares about the 2005 F1 season. Rebellion once tried Dunlop´s(which belongs to Goodyear) tailored made tyres for their LMP1 but soon went back to the generic tyre Michelin supplied them with(as Michelin focused on the big manufacturers and only made tailored tyres for them).
I would definitely love to see Pirelli displays their immense capability_ without the "tight restrictions that the FIA and F1 imposes to them"_ in a series like SuperGT or WEC so that they could show how great of a tyre they are able to produce with insane grip and infinite durability rubber that would need no management right to the end. I wonder why they don´t do that but rather love to hide on spec series without tyre competition :-k
