Pyrone89
Re: Mercedes Power Unit Hardware & Software
ENGINE TUNER wrote:
24 Jul 2019, 00:10
Pyrone89 wrote:
23 Jul 2019, 20:04
Cooling bullet dodged, Sunday is forecasted to be only 25 degrees and even rainy. Will have to wait for Hungary to see if the rumored cooling fix works.
Canada, France and Silverstone were hot, Merc had cooling problems in Austria because of the combination of high ambient temperatures and also the high altitude. Hockenheim is not high altitude, so regardless of the temperature, Merc were going to be ok.
Sure it was a combo, but saying they would have been fine with temps of almost 39 degrees (now forecasted to arrive 2 days earlier) might be stretch. And I dont recall Silverstone, Canada or France being 35 degrees or higher such as Austria and the early Hockenheim forecasts said.
roon
roon
412
Throttle body before the turbo on F1 turbo engines
viewtopic.php?t=3012
566
Throttling pre turbo in general reduces compressor work and "vortex throttling" can significantly improve the compressor efficiency at part load. eg Rolls Royce Crecy nearly 80 years ago.
https://en.wikipedia.org/wiki/Rolls-Royce_Crecy
Supercharger throttling was used as well to achieve idling. The supercharger throttles were novel vortex types, varying the effective angle of attack of the impeller blades from 60 to 30 degrees. This reduced the power required to drive the supercharger when throttled, and hence fuel consumption at cruising power.
saviour stivala
saviour stivala
52
Who of the four present manufacturers uses a throttle body before the compressor intake?, if it is permitted by the rules that is.
63l8qrrfy6
63l8qrrfy6
368
roon wrote:
24 Jul 2019, 00:28
Mudflap wrote:
23 Jul 2019, 23:41
roon wrote:
23 Jul 2019, 19:38
It would appear the compressor inlet stator vanes can be used as a throttle. If so, for what use?
Throttling the compressor might reduce MGUH power requirements for spool up.
They are there strictly to provide pre-whirl at part load.
They appear to be capable of fully shuttering closed. Which implies function beyond inducing helicity.
https://www.youtube.com/watch?v=HwALos8CwJ0&t=22s
Watch the first 15 minutes or so - he explicitly says how it operates.
The fact that he is a former Merc Brixworth employee is no coincidence ;)
The engine throttling is still done by conventional throttles located above the inlet ports.
63l8qrrfy6
63l8qrrfy6
368
roon wrote:
24 Jul 2019, 06:20
I am fairly sure that in the first turbo era pre compressor throttles were only used to lower inlet pressure and avoid stall when the main throttle was shut.
566
saviour stivala wrote:
24 Jul 2019, 11:12
I can't imagine the benefit of a rule to outlaw an upstream throttle. I doubt such a law exists.
saviour stivala
saviour stivala
52
Mudflap wrote:
24 Jul 2019, 22:19
roon wrote:
24 Jul 2019, 00:28
Mudflap wrote:
23 Jul 2019, 23:41
Did the former ex Brixworth employee said the system is being used by Brixworth?.,
63l8qrrfy6
63l8qrrfy6
368
25 Jul 2019, 07:34
Mudflap wrote:
24 Jul 2019, 22:19
roon wrote:
24 Jul 2019, 00:28
Did you not see the picture posted by roon on the previous page that started this conversation?
roon
roon
412
Mudflap wrote:
24 Jul 2019, 22:19
roon wrote:
24 Jul 2019, 00:28
Mudflap wrote:
23 Jul 2019, 23:41
russian swirl throttle
Might confuse the bartender with that one. "One part vodka, one part vermouth, one part aviation spirit, dash flow-viz..." Anyway. Does he go in to what happens when the vanes fully close?
645
in hand before roon's post above ....
the USSR seemed to be the only player in WW2 that had 'vortex throttling' in aircraft engines
(Callum Whatisname might be mentioning in his book and has mentioned in talks WW2 German work/opinion on this ?)
Poland (so France ?) had a VT line of work which was known in GB
potential VT benefit was most eg in eg British WW2 fighters at takeoff - but only when using VP/CS props with 80/87 fuel
before this fixed pitch props had needed much less throttling for boost regulation at t/o (less rpm so boost much less)
and afterwards 100/130 fuel then 2 speed supercharging alleviated the throttling-for-boost-regulation issue
though yes - all boosted aircraft engines (and even a few NA) had manual or automatic TFBR
(all boosted except Kinners that were by design below 1 bar abs - ask Harrison Ford)
manual means eg at takeoff you don't give 'full throttle' - you throttle to stay down to the specified MAP eg 38"
I never asked 'old school' pilots what they actually did - though some have written or spoken about this in interviews
British engines were all automatic
in 1940 the fighters went overnight from 1050 t/o hp to 1310 t/o hp by resetting the autoregulation for 100/130 fuel
V16 BRM fans and RR Crecy fans (why ?) see VT as the 'holy grail'
(I here give my apologies to those people enthusiastic in their regard of actual holy grails)
63l8qrrfy6
63l8qrrfy6
368
Tommy Cookers wrote:
25 Jul 2019, 09:43
I did read an article of his where he was talking about a captured russian plane examined by the germans. I think it lead them to develop their own variable guide vanes but I can't remember whether they ever made it into production.
63l8qrrfy6
63l8qrrfy6
368
roon wrote:
25 Jul 2019, 09:30
Mudflap wrote:
24 Jul 2019, 22:19
roon wrote:
24 Jul 2019, 00:28
Nope, but again I don't see why they would do that.
Craigy
84
Interesting that Andy Cowell mentions the ES can output 200kW in this video (around 3mins in) https://www.youtube.com/watch?v=3C1-KDkGDUA
Obvious comment is obvious, but the ERS K can deploy 120kW, so you'd have to assume the other 80kW is for the H.
subcritical71
90
Craigy wrote:
02 Aug 2019, 21:17
Which I believe is right where henry has calculated the H power consumption at for quite some time now. =D>
