Ferrari F138
amouzouris
105
Re: Ferrari F138
Crucial_Xtreme wrote:Scarbs take on the new F138 FW:
The front wing is the most interesting part. The cascade winglet mounted to the wing's endplate has completely changed. Rather than being a horizontal wing, the element is now curved such that it meets the wing in an 'r' shape.
The revised cascade wing will probably create downforce, but the change is more likely to be about modifying the way the winglet bends the airflow around the outside of the front tyre. The new outer vertical section of the winglet will be quite effective at turning the airflow.
Link
He also says he's told the pelican noses actually do add downforce even if their design is counterintuitive at first sight, as it appears they would add lift not downforce.
I agree with scarbs about the new cascades and i definitely agree with him on the pelican noses! I've been saying this for a while now. I have also found an added advantage with the kind of pelican noses lotus and red-bull are running and to the one sauber tested, although theirs is much more extreme. it gets more air under the nose to the rear of the car. I'm not really sure if the kind of pelican nose ferrari brought will still have this effect.
Re: Ferrari F138
It's a venturi effect, isnt it ?
They also kept the converging FW/nose supports but their angle looks less extreme to me:
stefan_ wrote:Canda 2013 - Friday (07.06.2013)
Before
Maybe it's just view angle...
bar555
bar555
Re: Ferrari F138
in Ferrari case the pelican shape ( i prefer to call it slant instead of Pelican though) seems to have a more direct effect than the rounded corresponded noses of Lotus and Sauber . Just for history, Renault first adopted a slant nose in 2009
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
Forza
238
Re: Ferrari F138
Tobias Grüner wrote:The bulge under the @InsideFerrari nose is just attached. So no extra crash test needed. See the little gap
amouzouris
105
Re: Ferrari F138
bar555 wrote:in Ferrari case the pelican shape ( i prefer to call it slant instead of Pelican though) seems to have a more direct effect than the rounded corresponded noses of Lotus and Sauber . Just for history, Renault first adopted a slant nose in 2009
I think there has been a benetton in the 90s with a similar nose...let me find it
Edit:
it was the B193. It is not a pelican nose. the front of the nose is similar but as you said the pelican noses as we see them today were first used by Renault in 09
Re: Ferrari F138
Forza
238
Re: Ferrari F138
Canada GP - Saturday - 8/6/13
Re: Ferrari F138
Testing for 2014?
Re: Ferrari F138
Re: Ferrari F138
Canada 2013 - Saturday (08.06.2013)
Click the picture for hign rezolution
Pierce89
Re: Ferrari F138
I was out of town today. Did Ferrari run the new sidepods in quali?
Huntresa
Huntresa
Re: Ferrari F138
Pierce89 wrote:I was out of town today. Did Ferrari run the new sidepods in quali?
I think Alonso ran all the new updates.
armyk
armyk
Re: Ferrari F138
I guess both used short sidepots = old, right?
henra
henra
Re: Ferrari F138
I'm not sure the Ferrari version is aimed at exactly doing the same as the 'Pelican' ones.
This here represents effectively an 'Air dam'. The increased pressure in front of the relatively blunt slant will force more air over the nose. So besides the (more pronounced) low pressure effect directly behind the horizontal mid part of the FW it seems they try to alter the whole airflow around the nose to some extent with this solution. (Towards more front DF and more air over the car instead of around it).
Is Canada considered a front limited circuit?
Or are they experiencing first signs of 'choking' of the rear undercut underneath the exhaust bulges)?
Cuky
65
Re: Ferrari F138
armyk wrote:I guess both used short sidepots = old, right?
Fernando used new sidepods together with "bridge" at front. Onboard shot from Q2 if I am not mistaken
