Ferrari F1-75
Sansovino
Sansovino
Re: Ferrari F1-75
mzso wrote:
25 Jul 2022, 09:54
So why couldn't Leclerc reverse? Is it another defect of the car?
From what I heard the throttle was broken.
aran.vtec
aran.vtec
Re: Ferrari F1-75
Sansovino wrote:
25 Jul 2022, 12:14
mzso wrote:
25 Jul 2022, 09:54
As he crashed it sounds like the car was idling much higher than the normal F1 rpm idle (like throttle was stuck at 10% or something), After he mentioned the throttle , his engineer said "ok its a 0% now" as if it wasn't going back to 0 to allow it to engage reverse.
Sylv1
Sylv1
Re: Ferrari F1-75
Hello all, sorry for my ignorance, but when I see this kind of image from below the floor, I wonder. the floor inlet sends more air to the outside of the car than to the venturi tunnels. doesn't that create a lot of positive lift on the middle of the car?
sorry for my poor english
LM10
LM10
122
Re: Ferrari F1-75
Ferrari made a habit of showing their new floor to everyone right after bolting it on.
Re: Ferrari F1-75
Sansovino wrote:
25 Jul 2022, 12:14
mzso wrote:
25 Jul 2022, 09:54
Binotto said post-race and it's obvious from the onboards that Charles' references to throttle were about trying to get out of the wall in reverse (but the nose was stuck). The throttle issue from Austria did not return
LM10
LM10
122
Re: Ferrari F1-75
Vanja #66 wrote:
25 Jul 2022, 07:36
Blackout wrote:
25 Jul 2022, 00:43
Did they sculpt the red area so that created a front facing step (red arrow) that looks like the RB one?
Left pic = Imola (AMuS) - right = French GP @DANIELEALOFAN
The mini diffusers at the boat tail are still there but not very visible, or not as agressive ?
https://pbs.twimg.com/media/FYdyjblXgAA ... ame=medium
Great comparison angles, as expected this is a completely new floor altogether. They did what RB did with the step (red arrows), using it to narrow down the keel to let more air to the floor, then introduce a hard outward flick to help run the air outwards to the throat. The chassis department is doing the best job on the grid, the car is perfect in all conditions.
I agree with your last statement. Best chassis, best car overall. What a beast that thing is. Even more of a pity that they can’t put everything together and win the races. But that’s a different story.
Is there a unique design on that new floor or is it their old ideas mixed with RB’s?
Re: Ferrari F1-75
Slightly different angle.
Re: Ferrari F1-75
mzso wrote:
25 Jul 2022, 09:43
You can clearly hear the bouncing on the straights on on-board videos.
Touching the ground isn't a problem when it's at the low frequency Ferrari has currently.
Re: Ferrari F1-75
Sylv1 wrote:
25 Jul 2022, 12:31
AFAIK, if the underbody inlet had no fences like that, it would create a lot of lift indeed. That's where the fences come in handy, they are like wings placed vertically so they will create suction behind them (behind the last fence, the inboard one) so they create local downforce. And that high suction area (purple below) will pull air inside the ventury tunnels.
+ the fences will create vortices along the tunnel that reduces the pressure even more
viewtopic.php?t=28657
RZS10
359
Re: Ferrari F1-75
Stretched one image to hell and back to make it fit the other ... at the back it looks straighter compared to the rounded shape it had previously? Just left of the plank at the rear/bottom where the (no longer present?) side-mini-diffuser used to be
edit: Here's the area, not easy to make sense of the shape, looks like an indentation or at least several steps judging by the shadows and the bit in blue?
Re: Ferrari F1-75
LM10 wrote:
25 Jul 2022, 12:54
I think there are several solutions from other cars, packed together in a unique way. This new stepped inlet was actually something Mercedes did with their launch-spec.
RZS10 wrote:
25 Jul 2022, 15:02
It's just different reflections and a curvature between vertical and horizontal surfaces. I don't think there would be any benefit of introducing a step there.
johnny comelately
johnny comelately
110
Re: Ferrari F1-75
This might help, maybe hypothesising at the 2:30 mark
Sansovino
Sansovino
Re: Ferrari F1-75
25 Jul 2022, 12:39
Sansovino wrote:
25 Jul 2022, 12:14
mzso wrote:
25 Jul 2022, 09:54
Yeah I knew it wasn't a repeat of the Austria issue. I assumed it was fully broken.
Anyway turns out, at least from reading this article and they directly quote Binotto and Leclerc, that it was a clutch issue.
https://www.crash.net/f1/news/1008537/1 ... io-message
tpe
tpe
-4
Re: Ferrari F1-75
There is a safety mechanism/procedure that a driver has to follow in order to engage reverse. Apparently, this procedure either was not followed or it didn't work. But it's not clear what is the case.
tpe
tpe
-4
Re: Ferrari F1-75
johnny comelately wrote:
26 Jul 2022, 09:01
I am always impressed by their graphics... Amazing work.
