Ferrari F2012
Pup
Pup
50
Re: Ferrari F2012
I think they've said that the problem is that the balance shifts, and does so unpredictably.
xpensive
xpensive
214
Re: Ferrari F2012
timbo wrote:
xpensive wrote: ...
Those fat wishbones tells a story about high compression forces and the short pull-rod travel makes the window of stiffness
and progressitivity xtremely small and delicate to adjust I can imagine.
As already said what's important is damper/spring travel, and that can be adjusted by a rocker.
I'm afraid it's not that simple in reality, there's clearance and deflection in everything, while the smaller the displacements and higher the loads, the more those two evil parameters count. To a detrimental effect I should add.
Chuckjr
37
Re: Ferrari F2012
Does anyone here know or have a pulse regarding the Ferrari chassis update for Spain? Are they going to try and make the Jerez day one exhaust work or are they going to try and copy RB or Macca's solutions?
Watching F1 since 1986.
Lycoming
Lycoming
106
Re: Ferrari F2012
I imagine it would be easiest to copy their solution. At minimum it seems to work. At this point where they wan to turn things around and be at least at their level ASAP, I think that would be the smartest thing to do at this stage, though thats probably not the only issue that they need to deal with.
that said I have no idea what their actual plan is. No upgrades for malaysia though.
xpensive wrote: I'm afraid it's not that simple in reality, there's clearance and deflection in everything, while the smaller the displacements and higher the loads, the more those two evil parameters count. To a detrimental effect I should add.
The wheel movement and spring/damper movement is more or less the same as it is in a pushrod setup. Its only the amount of movement of the linkage itself that changes and the method of loading. can you clarify what those effects you mention are, how they arise and what effect they have on vehicle dynamics in a clearer way?
Pierce89
Re: Ferrari F2012
Chuckjr wrote:If the back end of the car is loose (as it has clearly shown to be), wouldn't common sense tell you the front end is gripping so much that the rear cannot keep up--in this case, the front is working so well that its emphasizing the rear problems? It seems insessent pushing would be more of a barometer for a front end fundamental problem than a loose rear end?
Sounds logical, but it's well known that some drivers detest understeer so much that if the front isn't pointy enough and they can't dial in any more front grip, they'll start intentionaally throwing away rear grip.Which could make a car with bad front grip look oversteery instead. I don't think this is the case at Ferrari. Just pointing out that little caveat in your otherwise perfectly logical and succinct post.
bhall
bhall
244
Re: Ferrari F2012
It wouldn't surprise me at all to discover that everyone who's posted any ideas whatsoever about the F2012's problems is correct in their assertion(s).
Froggolo
Froggolo
Re: Ferrari F2012
bhallg2k wrote:It wouldn't surprise me at all to discover that everyone who's posted any ideas whatsoever about the F2012's problems is correct in their assertion(s).
i am badly afraid you are right :cry:
Relax, man. Have an elliptical drink or something® ( bhallg2k )
xpensive
xpensive
214
Re: Ferrari F2012
Lycoming wrote: ...
That is true, it's the pull-rod linkage that becomes the problem when suspension energy is transferred from movement to force, every joint has an inherent clearance and stiffness and the more force and less movement, the more said parameters count in a relative way, ie the linkage becomes less precise.
Then an ancient rule of thumb says; spring should be compressed, rods should be pulled, never the reverse.
With a higher pull-rod force, compression forces in the wishbones increases, why they need to be beefed up, which can clearly be seen on the F2012. The pull-rod itself could be made rather sleek though, when it's in tension and not compression, as can be seen on the Red Bull rear with its simplistic but elegant turnbuckle.
With a push-rod, the rod itself needs to be sturdy to handle shock-loads without buckling, but the wishbones are in tension which suits the carbonfibre structure much better, why they can be made very sleek, see the MP4-27.
kebab
kebab
Re: Ferrari F2012
One thing I still dont understand is that one 1 hand we say the car rear end is too loose and on the other hand we say its due to the exhaust. I think exhaust problem only contribute while the car is cornering and the exhaust blown has already been banned. On the straight this should not be a problem, no?
Im worried that the problem with the car isnt only it exhaust or the acer duck, some bigger things are wrong and I hope this isnt the case.
timbo
timbo
113
Re: Ferrari F2012
kebab wrote:One thing I still dont understand is that one 1 hand we say the car rear end is too loose and on the other hand we say its due to the exhaust. I think exhaust problem only contribute while the car is cornering and the exhaust blown has already been banned. On the straight this should not be a problem, no?
I'm with Scarbs -- the pitch-sensitivity of the car is the problem. The whole rear aero probably works OK when the car is on the straight line or on fast curve (neutral attitude), but on the corner exit (nose up attitude) the airflow is probably disrupted to a degree. They probably try to compensate it with harder rear suspension but that also promotes oversteer.
2xpensive -- if they have problems with front suspension due to what you say, it should probably cause understeer on the corner entry. Not the trait F2012 shown so far, no?
myurr
myurr
Re: Ferrari F2012
To me that sounds a lot more plausible than many of the suggestions flying around here. It could also help explain why their car seems to be so inefficient - they lack rear downforce but still have huge amount of drag. If they are generating plenty of downforce from a draggy car but are then losing it at times does to pitch sensitivity then that would explain their straight line speed. Coupled with a higher CofG at the front and I can see how that would all add up to a poor handling car.
If this is the case then I'm afraid that's not something they're going to fix this year. They may tame it a bit but I don't think I've ever seen pitch sensitivity tuned out of a car within a season.
BalazsSzabo
BalazsSzabo
Ferrari F2012
I just thought to open up a new thread regarding Ferrari's this year's car.
I have just read a translation from Autosprint:
"In May a new version of the F2012 will arrive in Barcellona, they are going to use the original configuration of the exhausts system which is the most efficient but in this way the tyres are heated too much.
Ferrari has changed his exhausts system at the last moment so there is a big part of the bodywork which is unused and causes drag. Also, modifing the sidepods is very difficult because they have to change the resonance waves of the engine."
What does 'the resonance waves of the engine' mean?
f1316
f1316
84
Re: Ferrari F2012
Read this on Speed tv:
"Another Spanish newspaper, AS, reports that Ferrari is pressing the throttle on a 'plan B,' involving a substantial redesign of the F2012 chassis for China that will involve a new FIA crash test."
So a new chassis for the third race? With no testing? That's risky, but actually the kind of balls I think it's going to take for them to get anything out of the season.
FakeAlonso
Re: Ferrari F2012
Ferrari Sepng
FrukostScones
163
Re: Ferrari F2012
duct for driver cooling/f-ducking
