Ferrari SF-24
bagajohny
bagajohny
Re: Ferrari SF-24
19 Feb 2024, 11:10
18 Feb 2024, 15:50
Better quality comparison photos of the two different engine covers run in the filming day
I believe most of the difference in appearance is due to lighting, but there's certainly a large difference in terms of sharkfin
📸 Ama.m_photo
https://i.imgur.com/zy1uEPa.jpeg
Article talks about the engine cover comparison and clarified that the spec 1, trimmed engine cover is the one that will be in use for the season
And they also talk about the car being able to run higher wings without balance issues unlike the sf-23. Which means tyre wear can be better and drs effect can be greater
Looks like due to cost cap they decided to invest in new rear wings rather than new rear suspension.
wowgr8
wowgr8
29
Re: Ferrari SF-24
19 Feb 2024, 11:10
I thought the wing looked small from the side/.75 angle but from this thumbnail it looks huge. Close to full size
Farnborough
Farnborough
101
Re: Ferrari SF-24
The rear suspension IS new, to not understand this shows significant lack of knowledge as to what they've worked on.
The rear wing is now exposed to fundamental change in upstream airflow....this from moving the side impact lower provision and opening the volume of air going through that space between the floor top and sidepod underside, ultimately making the entire rear flow architecture conform to new design direction.
The NEW rear suspension has been designed to optimum in enhancing underfloor flow volume/strategy, also feeding into difference in rear wing provision to accommodate these considerable developments.
Re: Ferrari SF-24
There's very little change in upstream flow for rear wing, all of it is in the airbox/Halo level and above. The reason behind the redesign is DRS effectiveness, this has been confirmed by the team. I would say it's also meant to "drive" the beam wing in a bit different manner than 22/23 cars did. The new RW range will be designed in the same manner as Spa 23 low-df wing, which was also combined with a single-piece beam wing:
wowgr8
wowgr8
29
Re: Ferrari SF-24
Interesting that they're back to curving the bottom of the DRS flap, this was a big factor in their DRS weakness at the beginning of 2022, which they began to fix with the Austria spec wing that year where the flap was made as big as possible, why would they then go back to curving the bottom edge like that and reducing the flap size?
FDD
FDD
80
Re: Ferrari SF-24
Cover specifications used in Fiorano
SharkY
SharkY
Re: Ferrari SF-24
wowgr8 wrote:
19 Feb 2024, 14:19
Is it reduced, though? With the shape of the wing that they chose (higly convex in the middle) the cord length of the DRS flap is more or less proportional to the cord length of the entire wing along the wingspan. To make the flap flat, they'd have to reduce its size, as I doubt there's room to increase the cord legth at the wingtips.
BTW this is a Rear Wing and as always there will be several iterations for different tracks.
FDD
FDD
80
Re: Ferrari SF-24
bagajohny wrote:
19 Feb 2024, 12:51
19 Feb 2024, 11:10
18 Feb 2024, 15:50
📸 Ama.m_photo
But they also redesigned the rear suspension.
Ced
Ced
Re: Ferrari SF-24
19 Feb 2024, 11:10
18 Feb 2024, 15:50
📸 Ama.m_photo
That RW looks a bit like the one redbull used to run in bahrain the last two years..
Venturiation
Venturiation
98
Re: Ferrari SF-24
Re: Ferrari SF-24
FDD wrote:
19 Feb 2024, 15:43
https://formu1a.uno/wp-content/uploads/ ... -white.jpg
What would be the purpose of this? Yaw control? Generating downwash from the departure angle of the fin?
A lion must kill its prey.
dialtone
dialtone
121
Re: Ferrari SF-24
FDD wrote:
19 Feb 2024, 15:43
Shark fins help the car turning
Muramasa666
Re: Ferrari SF-24
FDD wrote:
19 Feb 2024, 15:43
Can a more pronounced shark fin increase the wind sensitivity of the car?
bagajohny
bagajohny
Re: Ferrari SF-24
dialtone wrote:
19 Feb 2024, 18:04
FDD wrote:
19 Feb 2024, 15:43
How do they help in turning?
dialtone
dialtone
121
Re: Ferrari SF-24
bagajohny wrote:
19 Feb 2024, 19:25
dialtone wrote:
19 Feb 2024, 18:04
Good explanation.
