McLaren MCL38
Venturiation
Venturiation
101
Re: McLaren MCL38
Macafangrskg
Macafangrskg
Re: McLaren MCL38
I saw it live the last run before the break with the flowviz and there were almost no spillage over the sidepods. Just a smudge
Our small wing works like Merc 22 car
michl420
michl420
Re: McLaren MCL38
f1rules wrote:
21 Feb 2024, 12:46
do we have a small double keel like in the good old days :-)
https://pbs.twimg.com/media/GG2uK71XMAA ... name=large
I "saw" that too. A reason could be of course a better kinematic, but with the new moved back steering arm it creates a nice three element downwash "wing" right in front of the floor entrance. And on top there is a very low and rearward suspension leg from the upper wishbone.
LionsHeart
LionsHeart
Re: McLaren MCL38
Well, looked at both the broadcast and here in the photos: the bottom edge has changed in an evolutionary way. I didn't see anything unusual. Among the things that stand out is the rear upper arm of the front suspension is strongly pulled back closer to the side pontoons, as well as the position of the steering link. The geometry of the diffuser has changed slightly compared to last year. Otherwise, we can see a general evolution of the chassis and aerodynamics. Nothing out of the ordinary.
stewie325
stewie325
Re: McLaren MCL38
Very interesting how the air separates in two directions around the rear-most suspension arm.
LionsHeart
LionsHeart
Re: McLaren MCL38
stewie325 wrote:
21 Feb 2024, 13:44
Magic vortex generation. 😁
michl420
michl420
Re: McLaren MCL38
Whats that second (suspension?) element right in front of the push rod/have damper mounting point?
https://pbs.twimg.com/media/GG2wxU3XAAA ... =4096x4096
f1rules
f1rules
621
Re: McLaren MCL38
:D
Honestly i think the car from my armchair looks good with many optimized areas. Last year they already had one of the best cars aerodynamicly, maybe not drag, but df and almost equal to rb in high speed
The 38 builds on that and with the following goals, according to mclaren. Less drag, better mech grip, better tyre interaction
So based on that they have
> More agressive undercut
> Pod wing, the only team with that
> Significant smaller(width) airbox inlet which should help flow to the rear making it more effective
> Derived from this, I think they moved a bit of center cooling to the sidepods, maybe for lower COG
> Deep sidepod channels like most
> Heavily updated rear suspension and according to amus change in rear spring design and definitly more anti dive
> Heavily updated front suspension with more anti dive. Im no suspension expert, but conventional and conservative i get the sensation, its definitly not. Just hope it works :-) as its almost impossible to change in season
So honestly, if this car works as intended, it could be a good season
venkyhere
venkyhere
Re: McLaren MCL38
Is this the 2024 car ? how come the sponsor on sidepod inlet changed from 'VUSE' to 'VELO' ?
FittingMechanics
FittingMechanics
Re: McLaren MCL38
venkyhere wrote:
21 Feb 2024, 14:10
Both Vuse and Velo are subbrands of British American Tobacco (remember BAR?).
Depending on location they change the brand to what better suits them.
Farnborough
Farnborough
111
Re: McLaren MCL38
michl420 wrote:
21 Feb 2024, 13:56
Hard to tell from that image angle and without a correlating (different angle image) but LOOKS like a static external brace that could be taking load from different arm locations.
There's many links tagged onto that initial push/pull input on these, anti roll, heave spring, heave damper, the torsion spring itself, conventional individual wheel damper etc.
Amazing packaging in all of them, but detail appreciation slightly difficult without a good multi faceted view of them in clear sight.
All fascinating to see how the design team incorporate these parts.
f1rules
f1rules
621
Re: McLaren MCL38
f1rules
f1rules
621
Re: McLaren MCL38
amus highlighted
Ground Effect
Ground Effect
Re: McLaren MCL38
f1rules wrote:
21 Feb 2024, 14:04
:D
By the way @f1rules, thanks for all the great pics so far, really appreciated 👍
f1rules
f1rules
621
Re: McLaren MCL38
Thanks, no prob :-)
