Concept power units from 2030
670
Re: Concept power units from 2030
Tommy Cookers wrote:
24 Jul 2024, 21:05
24 Jul 2024, 20:45
there is nothing that compels the situation to be as the RET advice claims
fundamentally motor torque is always proportionate to the conductor current
so it is always controlled by the F1 designer and rules not by RET
simply if said designer wanted he/she could command other torque/rpm behaviours
the implied immutable torque/rpm characteristic is merely what has been chosen in the settings of the so-called controller
the RET idea is in racing using EV-style fixed software-driven MG motoring behaviour
(ie 0%-n% rpm constant torque, n%-100% rpm constant power)
this can't be the ideal way round the track (in a strongly electric F1)
surely every part of the track and race will have its own best way of spending electrical energy
whether or not we have gears
Rodak
Rodak
37
An interesting review of turbo-compound engines.
https://www.youtube.com/watch?v=gbMgwDIdScY
670
yes but ....
the expansion ratio CR=6.7 of those engines was about 30% of F1's CR=18 expansion ratio
so there was far more waste power to be recovered
the 911 MGU-H turbo recovers about 3% of the ICE power
saviour stivala
saviour stivala
43
The CR=6.7 of those engines (The Wright turbo compound). 6.7:1 Was the design selected compression ratio to optimize the engine performance according to the application and available fuel type.
Hoffman900
Hoffman900
243
01 Aug 2024, 14:01
yes but ....
Not entirely true. F1 engines are Miller Cycle and IVC occurs before BDC, so without knowing where IVC is, you can’t really make that distinction.
Not sure what your point is here continually bringing up 80yo NACA papers and 90yo designs.
Hoffman900
Hoffman900
243
28 Jul 2024, 22:52
24 Jul 2024, 21:05
24 Jul 2024, 20:45
RET was quoting a FE motor supplier.
F1 I literally linked two example: one a research paper from Ferrari another from Honda.
None of these examples can’t be any more direct.
579
Hoffman900 wrote:
02 Aug 2024, 00:31
01 Aug 2024, 14:01
yes but ....
Miller valve timing has no effect on expansion ratio.
Hoffman900 wrote:
02 Aug 2024, 00:31
He is responding to @Rodak's immediately preceding post.
saviour stivala
saviour stivala
43
Yes. he is fixated with that 80-year-old technology, and there is nothing wrong in that, but then interprets that 'BLOW-DOWN' technology harnessed incorrectly.
670
Hoffman900 wrote:
02 Aug 2024, 00:32
28 Jul 2024, 22:52
24 Jul 2024, 21:05
clearly (I think) ....
the fastest way round the track is to run as long as possible at constant torque then go to zero torque (coast)
not less time at constant torque then time at reducing torque with speed (aka constant power) as per RET etc
579
TC when you say "constant torque" do you mean at the traction limit? Disregarding cornering this is undoubtedly true although in reality the traction limit increases considerably with velocity thanks to aero. . . and we are talking rear wheel torque of course.
Chuckjr
This must be why there is concern that the ICE will be at full revs around places like Lowes hairpin in Monaco — as ICE will mostly act as a recharge facility for the batteries so that constant torque is available from the motor to drive the rear wheels. Like a diesel train, essentially? Because it’s so efficient, and efficiency will win the race with the way they are going with power units in 2026. Hope that’s correct.
Watching F1 since 1986.
579
Chuckjr wrote:
03 Aug 2024, 07:12
Best put silencers on them so we don't get to hear that sh1t.
mzso
mzso
75
Chuckjr wrote:
03 Aug 2024, 07:12
Well, if they can rev the engine in neutral it's possible, I think. Otherwise I don't think such gearing exists to do full revs.
saviour stivala
saviour stivala
43
mzso wrote:
06 Aug 2024, 21:29
Chuckjr wrote:
03 Aug 2024, 07:12
Isn't an engine capable to rev at full revs in all the gears, or better put, aren't all gear designed/calculated so as the engine can reach full revs in each one?.
670
saviour stivala wrote:
07 Aug 2024, 07:45
mzso wrote:
06 Aug 2024, 21:29
Chuckjr wrote:
03 Aug 2024, 07:12
no .... not in 25 mph hairpins
first gear corresponds to peaking at about 100 mph
