Can already see the influance of PD. His attention to detail is super great:
Somers F1:
McLaren continue to make tiny steps at improving the MP4-29 toward the end of the season and as you can see when comparing the image taken above (by Giorgio Piola), with the one used previously, we can see that some small notches have been removed from both the trailing edge of the Endplate and the most rearward wing element. You'll note that the notches are not new just enlarged and so it seems that the team are keen to make these ad-hoc changes in order to increase how the flow moves around the front tyre. I'd be interested to know if they went to the expense of making a new endplate for this test as in reality a dremmel may well have dealt the same blow. However we can see that the shaping of the rear wing element has been re-designed, with the outer portion now forming a sort of Gurney, further enhancing the way in which the airflow is outwardly turned"
Positive for 2015
