Mclaren Mercedes MP4-25
jason.parker.86
jason.parker.86
Re: Vodafone Mclaren Mercedes MP4/25
Wow, yeah maybe Macca finally know how much downforce to run with this MP25! Certainly think they was too cautious in the opening few races of the season with it
Richard
Richard
NaZzO wrote: Those numbers are too low for top speed. maybe you are referring to sector 1 top speeds.
The actual speed traps for Montreal are: Petrov and Kubica @ 324kph, Alguersuari and DiGrassi @ 323kph, and Button @ 320 kph.
Those are still available in the f1.com live timing application. Look for it in the weather and speed tab.
http://www.formula1.com/live_timing/liv ... popup.html
Well spotted - thanks.
They were only 5kph behind 325kph. Surprising to see RB down at 312 kph
The real numbers are below, and can be downloaded from this link ...
viewtopic.php?p=178036#p178036
Code: Select all
POS  NO DRIVER 		KPH 	TIME OF DAY
1    12	V. PETROV	324.7 	12:08:53
2    11	R. KUBICA 	324.2 	12:04:26
3    17 J. ALGUERSUARI 	323.2 	13:03:55
4    25 L. DI GRASSI 	323.0 	13:21:17
5    16 S. BUEMI 	322.8 	13:04:37
6    1 	J. BUTTON 	320.1 	13:14:34
7    23 K. KOBAYASHI	320.0 	12:04:29
8    15 V. LIUZZI 	320.0 	12:51:43
9    14 A. SUTIL 	319.9 	12:36:04
10   2 	L. HAMILTON	319.8 	13:14:30
11   22 P. DE LA ROSA 	319.6 	12:22:57
12   8 	F. ALONSO 	316.9 	12:49:27
13   7 	F. MASSA	316.5 	13:09:26
14   19 H. KOVALAINEN 	315.2 	13:16:13
15   4 	N. ROSBERG	315.1 	12:48:30
16   3 	M. SCHUMACHER 	314.8 	12:29:34
17  18 	J. TRULLI 	314.7 	12:23:10
18  9 	R. BARRICHELLO 	313.4 	12:28:50
19  10 	N. HULKENBERG	313.1 	13:31:00
20  5 	S. VETTEL	312.1 	12:45:31
21  6 	M. WEBBER	312.0 	12:07:14
22  20	K. CHANDHOK	309.7 	12:07:32
23  21 	B. SENNA	309.3 	12:06:02
24  24 	T. GLOCK	308.8 	12:11:43
Shaddock
Blackout wrote:Look how steep and large that wing (mclaren Wing) is...
If you run that much wing compared to the other cars and can stay within 4-5kph of the front runners then the F-duct is working minor miracles at the back of the car.
However, with no real corners the extra DF was only useful for braking and trackion at the last race. Valencia requires slightly more DF than Canada and so it should suit the 25 even more than Canada did.
Monza with less DF than Canada will allow them to run a similar wing, but again the benefits may only be seen in braking and traction zones.
230
The downforce was useful as well to give the tyres a little more life, at least enough to equal ferrari in how it treats the tyres.
It also helps in braking.
PNSD
PNSD
I imagine at Monza a larger wing will help through the Lesmo's, ascari and parabolica. More importantly, good luck to anyone trying to follow that Mclaren through parabolica ;-)!
However, I suspect because of the unique demands of Monza, Mclaren will go for a much much more shallow wing.
Ferrari ran alot of wing here at Canada too it seemed!
Shaddock wrote: If you run that much wing compared to the other cars and can stay within 4-5kph of the front runners then the F-duct is working minor miracles at the back of the car.
However, with no real corners the extra DF was only useful for braking and tracking at the last race. Valencia requires slightly more DF than Canada and so it should suit the 25 even more than Canada did.
I disagree. Being able to run more wing than the others without straightline speed penalty will allow them to be a few mph faster in the Lesmo corners and the Parabolica. Both of these corners lead on to straights that end in chicanes (particularly the latter) which will mean decent overtaking chances at least twice a lap. The Variante Ascari may be taken quicker too which will also help in the run down to Parabolica.
I think that Monza, along with Spa, will be circuits at which a car without an f-duct will be easy pickings for those with an f-duct. The run down to Les Combes, for example, will pay real dividends. I wonder if Blanchimont might be taken with the duct operating too - there should be sufficient residual d/f for the corner. If this is the case then the f-duct cars will be mighty heading in to the Bus Stop.
Sadly for McLaren, the main title contenders will certainly have versions of the duct by then so the MP4-25's advantage will be minimised. Their real hope is that their version is the best and gives them even an mph or two advantage.
Shaddock
It's still only 3 corners for the whole track, and the second Lesmo isn't taken at high speed. At Parabolica they will have an advantage, and I would imagine in the same way they pick a braking point, they will have to pick an F-duct point during corner.
Traditionally this is the lowest DF track of the calendar, the F-duct will help, but the time will come in the same manner as Monaco - more DF give better traction/braking in and out of the chicanes.
That's what I said
Blackout wrote:
Gaara wrote:did mclaren use the f-duct in canada? because the top speed wasn't the highest :o
That means their F-duct is incredibly powerful: McLaren didn't brought a specific low downforce wings to Montreal; they used the Istanbul spec (wich generates a far greater amount of DF) ! and despite that, they had a competitive Top speed...
And make the tires last longuer thanks, like ringo said...
and in some turns; Monza also likes cars that naturally generate a good level of downforce, like just a fan said :lol:
Goran2812
Goran2812
27
the mclaren's ass looks a little fat compared to the ferrari, mercedes and sauber..
and that sauber has almost the same rear end lines and some details like the ferrari... nice photos for comparison!
Visit my photo page! -> http://www.gorankphoto.com/formula1
Goran2812 wrote:the mclaren's ass looks a little fat compared to the ferrari, mercedes and sauber..
Then you are looking wrong as the mclaren is the car with the tightest sidepod packaging, the only fat ass on the grid is the ferrari.
Goran2812
Goran2812
27
didn't say that it was... said that it looks like that from the pics... two different things...
Shaddock
Really when?
siskue2005
70
Re: Mclaren Mercedes MP4/25
very impressive from Mclaren =D>
And look at others wing, its seems the Mercedes is the car with more downforce than the Ferrari and Sauber! ...anyone? #-o
Pit
Pit
Hm.. Don't think anyone has posted this one yet.. Quite an entertaining one, and it shows a couple of nice details :]
[youtube]http://www.youtube.com/watch?v=4zf40OzfwOo[/youtube]
jason.parker.86
jason.parker.86
What id give to put that together...
