Flow Vis.mith wrote:Flow vis? Marks after the rain? Or just messy photo?
Yeah, they must be testing their blown flap.axle wrote:Flow Vis.mith wrote:Flow vis? Marks after the rain? Or just messy photo?
Why do you say that?gambler wrote:Looks like there trying to get some heat in hard compound tire on cold day.
BAR555, do you have comparative photo's of the diffusers as I've not noticed a change?!bar555 wrote:Upgrades from launch
1.Revised sidepod inlets ( 2 times in total )
2.Front brake duct
3.Sidepod panels
4.Modified rear bodywork
5.Major changes to the diffuser
From his blog:axle wrote:BAR555, do you have comparative photo's of the diffusers as I've not noticed a change?!bar555 wrote:Upgrades from launch
2.Front brake duct
3.Sidepod panels
Also, is the rear bodywork "modification" including the testing of a Redbullesq fin?
1.Taller catenary shaped central section.
2.Larger hole
3.The outer side tunnel was reduced in volume by moving the side wall closer to the vertical fence . The horizontal section has been analogously increased to reduce rear end pitch sensitivity .
4.The small fin , which is attached on the vertical outer diffuser side wall , has been redesigned and a thin wire connects it with the rear wing’s endplate lower tip
I think it's now on the top of the FIA standard wing between the pillars, so just out of shot on that picture.thedutchguy wrote:Has Williams stopped to put the Senna S logo on the inside of the front wing mounts?
