I can see a "fuel saving" mode activated if there are issues with the electric side of things that pop up during a race. Because of the fuel mass flow limitations, I would expect teams to run at max for the whole race and fill accordingly.wuzak wrote:There will be fuel saving, just so they can get to the end of the race. My understanding is that there may be a fuel allowance for each race.
In any case, F1 teams will put as little fuel into the car as they think they can get away with, and manage the fuel usage to get to the end. As they do now.
There are no fuel tank limitations under the current rules. Yet at most tracks the teams don't fill up the car to the maximum, nor do they put in the amount they would need for flat out racing. They use 5-10kg less than ideal and save fuel to make it to the end. I expect similar for 2014.dren wrote:I can see a "fuel saving" mode activated if there are issues with the electric side of things that pop up during a race. Because of the fuel mass flow limitations, I would expect teams to run at max for the whole race and fill accordingly.wuzak wrote:There will be fuel saving, just so they can get to the end of the race. My understanding is that there may be a fuel allowance for each race.
I haven't read the sporting regulations for 2014, but if you have to qualify on full fuel tanks, you could short fuel at a track like Monaco and run on a reduced fuel map if you think it would help to qualify at the front.
current cars are power limited by size and rpm, not by fuel quantitywuzak wrote: There are no fuel tank limitations under the current rules. Yet at most tracks the teams don't fill up the car to the maximum, nor do they put in the amount they would need for flat out racing. They use 5-10kg less than ideal and save fuel to make it to the end. I expect similar for 2014.
It is exactly what they do now. They don't have to limit themselves, but they do.Tommy Cookers wrote:current cars are power limited by size and rpm, not by fuel quantitywuzak wrote: There are no fuel tank limitations under the current rules. Yet at most tracks the teams don't fill up the car to the maximum, nor do they put in the amount they would need for flat out racing. They use 5-10kg less than ideal and save fuel to make it to the end. I expect similar for 2014.
current cars run very rich mixtures much of the time, a small gain in power is thereby available inefficiently, at the expense of of disproportionate consumption and very high fuel weight early in the race, also fuel weight is very much higher than 2014
the tradoff of these two factors determines how much fuel they choose to use inefficiently
fuel capacity limit is 195 litres I think
2014 cars will be able to get power proportionate to all fuel use allowed, all fuel used can and will be used efficiently
their fuel load is much less anyway
as ever, fuel not needed will not be carried, but they will not sacrifice (efficient) power to save small fuel weight
Just as renault team has nothing to do with infiniti.WilliamsF1 wrote:ecoboost has nothing to do with cosworth, just as ford has nothing to do with cosworth
ringo wrote:Just as renault team has nothing to do with infiniti.WilliamsF1 wrote:ecoboost has nothing to do with cosworth, just as ford has nothing to do with cosworth
I'm not British, I sometimes get mixed up with american ford and british ford and cosworth. Still a good idea though!
Funny that every road car engine has some form of variable valve timing mechanism, but for the road relevant 2014 f1 engine it is banned by the FIA.Ecoboost is just a name for small engine, Ti-VCT (Twin independent Variable Camshaft Timing) and a turbo charger
Is VCT really that beneficial when you're only operating over the narrow range of 10k rpm to 12.5k rpm?WilliamsF1 wrote:Funny that every road car engine has some form of variable valve timing mechanism, but for the road relevant 2014 f1 engine it is banned by the FIA.Ecoboost is just a name for small engine, Ti-VCT (Twin independent Variable Camshaft Timing) and a turbo charger
Cold Fussion wrote:Is VCT really that beneficial when you're only operating over the narrow range of 10k rpm to 12.5k rpm?WilliamsF1 wrote:Funny that every road car engine has some form of variable valve timing mechanism, but for the road relevant 2014 f1 engine it is banned by the FIA.Ecoboost is just a name for small engine, Ti-VCT (Twin independent Variable Camshaft Timing) and a turbo charger
