Mercedes AMG F1 W05
Moose
Moose
52
Re: Mercedes AMG F1 W05
dans79 wrote:
PhillipM wrote:Why? They're light, reliable, cheap and compact.
because they are plastic and melt pretty easily.
Being plastic doesn't imply they melt easily. There are plastics that remain solid at many hundred degrees C.
The lower triangle(if we can call it that) on Mercs front suspension is unlike anything i've seen.
I can't grasp what's going on there.
seinfeld
seinfeld
-7
PlatinumZealot wrote:
techF1LES wrote:Rear view of the Mercedes PU
http://img4.auto-motor-und-sport.de/Mer ... 815946.jpg
Now that's one huge azz turbo!
It's actually not. my turbo from my RX7 is about the same rear compressor size I guess they are similar models mine is a td04
new Ball bearing turbos from Garret like the GT 35R and 42R are MUCH BIGGER and are for 2 liter 4 cyl engines! so no not that big
Nice shot ( AMUS ) of the output of the Mercedes brakes, in Spain they had the shape of chimneys https://twitter.com/Graftechweb/status/ ... 4549685248
Perhaps not completely related or fully on topic (sorry about that; it's meant for future developments to show), but I made some alterations on my drawings to get closer to the W05 FW. Do you guys think it's an improvement?
old:
The thing is that it's extremely hard to draw since you are flattening to only 2 dimensions, while the wing twists and turns around several planes. It's important to get it correctly done since my believe is that little will change towards the W06, so important to get it right by then.
timbo
timbo
113
turbof1 wrote:The thing is that it's extremely hard to draw since you are flattening to only 2 dimensions, while the wing twists and turns around several planes. It's important to get it correctly done since my believe is that little will change towards the W06, so important to get it right by then.
I think the new one looks better, although it is indeed tough to workout shapes especially at places when there are few surfaces on different levels. Maybe you can try a bit of shading? At least on winglet area.
Gianlu27
21
https://twitter.com/Gianlu_DAle/status/ ... 5091990528
Mercedes: monkey seat comparison (Sochi-Montecarlo)
Follow me on Twitter: https://twitter.com/Gianlu_DAle
"Life is about passion thank you for sharing mine" Forza Michael!
noel
nico said they tried something 'creative' with the car, hence the lack of pace. anyone know what it was? new parts vis-à-vis 2015 or just setup-fiddle?
44 | 22 | 14
SectorOne
They experimented with setup, i think Rosberg was given the experimental route and Hamilton a more standard setup route.
Crucial_Xtreme
Crucial_Xtreme
404
Mercedes switched from the Monaco spec monkey seat to Spa spec in FP3 as well as RW spec
Yes, someone mentioned it was because the Williams are so fast they wanted a bit more straight line speed in case they had to pass them, interesting that they can just bolt them on and go without much setup work to adapt though.
MercAMGF1Fans
MercAMGF1Fans
Dunno if this has been mentioned, or has anyone got any better pics..
http://www.formula1.com/news/technical/ ... /1231.html
New Diffuser on the Merc
elf341
elf341
MercAMGF1Fans wrote:Dunno if this has been mentioned, or has anyone got any better pics..
Go back a couple of pages, it was at least tested at Suzuka -- I thought it was raced there too, so I'm a bit puzzled that the F1 website says it's a Russia innovation.
Gianlu27
21
mep
29
zioture wrote:Nice shot ( AMUS ) of the output of the Mercedes brakes, in Spain they had the shape of chimneys
That chimney in the lower picture is clearly illegal because it sticks out of the brake duct box.
I think it was only used during some test.
