Ferrari F138
majki2111
Re: Ferrari F138
nhojekim wrote:Is that a new diffuser?
I don't think so.
emmepi27
emmepi27
141
Re: Ferrari F138
I don't think so.
No new diffuser
imightbewrong
imightbewrong
Re: Ferrari F138
Massa: New (longer) exhaust, shorter mainplane on RW (but higher AoA), new FW (no cascades but the new flow conditioners/vortex generators + new cut pylons)
emmepi27
emmepi27
141
Re: Ferrari F138
Lateral difference between the two wings. More downforce in the ibrid version (sx), less in the dx version (testing in FP in Spa)
Re: Ferrari F138
Italy 2013 - Friday (06.09.2013)
Click picture for high resolution version
F1T
Administrative bot
Ferrari's Monza package, front end
Ferrari's Monza package, front end - Development blog
Ferrari have traditionally put a lot of effort into their home Grand Prix package, and this year is no different, although it seems that the other top teams have put in quite some effort as well. Contrary to Spa-Francorchamps where one needs great front stability along with less drag, Monza is even more about drag reduction and top speeds, as there are less corners that require a large amount of front downforce.
Just like many other teams, Ferrari brought a new front wing that features no stacked elements, along with a single, differently shaped flap. The interesting bits are the two vortex generators, standing vertically on the wing's main plane. The result are two vortixes immediately ahead of the inner sidewall of the tyre. It looks likely that the team hereby attempt to ease airflow over the front wheel, while on the inside of the wheels swirls air down towards the ground.
One other interesting element is the nose, which again features a small bulge underneath, contrary to the nose raced at Spa. Even though Fernando Alonso was also seen running with an older front wing with stacked elements, the bulge underneath the nose is a constant, at a circuit where one could expect teams to remove the bulge. Also notice that along with the different nose, the cameras have been relocated from in between the front wing pillars to immediately ahead of the steering arm.
joalma
Re: Ferrari F138
Front wing details Ferrrari F138 Vs Redbull RB9
GpMonza
Jose ‏@joalma1981
Re: Ferrari F138
THe nose buldge is to help stability under braking. So I would expect that for Monza.
Owen.C93
Owen.C93
177
Re: Ferrari F138
tony77g
tony77g
36
Re: Ferrari F138
differences of Ferrari to Friday
pictured below: long and short
Owen.C93
Owen.C93
177
Re: Ferrari F138
tony77g wrote:differences of Ferrari to Friday
http://www.zaslike.com/
Can't see any difference with the endplates.
Re: Ferrari F138
previously the rear part of the end plate was slotted. Now it is a continuous surface
tony77g
tony77g
36
Re: Ferrari F138
of course, I only pointed out where the changes have been applied rispeto the previous version. The two differ only in the picture in the main flap
Nathan
Re: Ferrari F138
Ferrari reverting back to the shorter exhaust for FP3?
shelly
shelly
136
Re: Ferrari F138
Low downforce wing has different upwash but also different inwash (in front of it) and outwash (behind it). Hence why the slot at the back of the endplate got replaced by a slot at the front in my opinion
twitter: @armchair_aero
