Aston Martin AMR22
AeroDynamic
349
Re: Aston Martin AMR22
Just_a_fan wrote:
11 Feb 2022, 19:45
I wonder if they'll make a "hot" panel and a "cold" panel for this area. Fewer gills in the "cold" panel.
Yeah, if the engine ends up running too hot with the 'cold panel' in that uk February weather, then their design has miscalculated a fair bit..
Hoffman900
Hoffman900
219
AeroDynamic wrote:
11 Feb 2022, 19:42
can someone break down other reasons why they are running with less gills other than testing how many they need?
To regulate temperature. Same reason you tape up brake ducts.
Pretty typical on all racing cars on exceptionally cool days, and especially if they aren’t going 10/10ths. You figure most of racing season is done in summer months, asphalt temps being north of 40* C, and in certain classes, you are drafting a lot (reduced airflow), so the brakes / radiator ducts are engineered for that.
Dangara
Jammin
Jammin
Is it just me or does anyone else notice the mock secondary side pod inlet is partially open on the actual car they ran today?
AeroDynamic
349
Silverstone Shakedown 👇🏽
Pandamasque
Jammin wrote:
11 Feb 2022, 20:33
Not seeing it.
Jammin
Jammin
Check aero dynamics 2nd and 3rd pic from page 19 at the bottom of the page. You can see a diagonal line similar to the one on the square opening. The edges look different too.
Zynerji
111
Jammin wrote:
11 Feb 2022, 21:24
pause the previous vid at 12s. its clearly solid. 32s as well.
Pandamasque
Jammin wrote:
11 Feb 2022, 21:24
The diagonal line is the inner edge of the square inlet, as seen from the top three quarter view. What was closed remains closed.
Mchamilton
Mchamilton
OO7 wrote:
10 Feb 2022, 19:34
I foresee a lot of front wing damage after minor contact happening this season.
Dont they have to made from an fia mandated carbon make up? To do the exact opposite, less damage and less shard all over everywhere when they do break
Jammin wrote:
11 Feb 2022, 20:33
It's just you.
Saykas
Saykas
26
Blackout wrote:
12 Feb 2022, 06:47
Sheesh. That's bigger than the wheels on my SUV? :wtf:
