McLaren MCL38
101FlyingDutchman
101FlyingDutchman
Re: McLaren MCL38
f1rules wrote:
23 Feb 2024, 12:27
thats all nice, but what about the weak frontend, would be nice to hear him mention that, since many mentioned during testing, it understeers like crazy
But i quess they dont need to worry about that as they are in the garage with ANOTHER issue :roll:
I don’t think you can just isolate it like that. If you don’t have the grip/df on the rear axle then you HAVE to balance it with the appropriate df level of the front wing. Potentially they’ve solved front issues with the altered suspension layout too.
If I had to hazard a guess, Cl / Cd (lift over drag or in F1 terms df / d) is the one area the RB20 excels in. Think most teams can easily match them on load but that’s where we are losing out big time on the RB
Re: McLaren MCL38
kediown
58
Re: McLaren MCL38
SilviuAgo
152
Re: McLaren MCL38
Wow..they have used all the flow vis on Oscar's car 😄😄
BigBeansBoy
BigBeansBoy
Re: McLaren MCL38
Does anyone know if this is still wet at this point? I’m no aero expert but it looks really strange to me towards the rear of the sidepod. The flow vis lines curve and then go straight down without an obvious downwashing element. Could this be aided by a combination of suction at the mouse hole and the vortex generated at the mid-wing?
De Wet
Re: McLaren MCL38
Our Rear Wing angles inwards quite a bit...
101FlyingDutchman
101FlyingDutchman
Re: McLaren MCL38
The air seems to make quite a bend down on the back end of the sidepod. Not sure if that is totally desireable. Slow speed performance in the technical S2 section seems pretty good! So possibly suspension kinematics working better this year
trinidefender
trinidefender
318
Re: McLaren MCL38
De Wet wrote:
23 Feb 2024, 15:31
https://i.ibb.co/VW2ycfM/GHAm-Ipc-XQAAnk3-I.jpg
It may do a bit more than other teams but if you look carefully you’ll notice that the picture is taken from a wider angle looking slightly in meaning any wing endplate angle that is there looks more pronounced
M840TR
M840TR
315
Re: McLaren MCL38
Anyone clear floviz pic that highlights sidepod wing vortex?
Mansell89
Mansell89
Re: McLaren MCL38
De Wet wrote:
23 Feb 2024, 15:31
Is there a reason ours and Mercedes rear wings are a bit thicker on the two side edges, especially in comparison to Red Bull?
hollus
Re: McLaren MCL38
Posts talking about gained tenths or pace comparisons have been deleted or will be shortly. The posters got (get) the text back, you are welcome to post them in the team thread or, perhaps better, the race threads.
As usual every year at this time:
a) Welcome to all the newbies!
b) No lap times, no track or championship position, no winning and losing in the car threads. Only hardware here, winning and losing goes in the team and race threads. Thanks.
In this particular case, some got deleted, the awesomest got moved (which takes a lot of time).
¡Puxa Sporting!
_cerber1
301
Re: McLaren MCL38
wiktor977
wiktor977
43
Re: McLaren MCL38
101FlyingDutchman wrote:
23 Feb 2024, 15:39
I remember that he was driving very slow, which is not normal during flow-vis test.
FittingMechanics
FittingMechanics
Re: McLaren MCL38
wiktor977 wrote:
25 Feb 2024, 20:14
23 Feb 2024, 15:39
It was definitely intentional. He did a whole lap on the pitspeed limiter (100kph). It makes sense to me, the flow of air changes as speed increases. If you want to verify what is happening at low speed, you do a low speed flow-viz run.
genarro
genarro
Re: McLaren MCL38
FittingMechanics wrote:
26 Feb 2024, 08:48
wiktor977 wrote:
25 Feb 2024, 20:14
23 Feb 2024, 15:39
wasnt that clutch problems related, that he did the whole lap in 2nd gear?
