Whether what works in principle? If you think running asymmetrical on front wing settings has some adverse effect on the cars stability, you would be incorrect. In fact it's used in practice frequently, especially on OW oval cars both on split front wings (different angles greatly effect the tire on that side) and candilever wings like F1 wings are, with a very minimal effect to the tire (side to side) because of the candilever wings due to the common attachment. BTW current OW oval car (Indy) are also cantilever, but still run different angles side to side, as in the draft, you can put a wing out from behind a car and still have half the draft and some grip on the front.myurr wrote:@speedsense - I'll maintain that it's an optical illusion until you show me a picture from in front of the car where it is 100% clear that the wings are at different levels. I can think of no aero reason for wanting to have an asymmetrical front wing, these cars are hideously complex and it isn't as easy as splitting the aero on the two halves of the car. By having radically different front wing angles on each half of the car you'd create all kinds of weird air flows from one half of the car to the other due to the air being directed to different places.
Perhaps, if a picture that proves beyond doubt that they're doing it cannot be found, then someone (ringo?) could knock up a quick CFD output to demonstrate whether it works in principle or not.
Please give some credit, as I do have a very trained eye on what my competitors are doing for wing angles and aero adjustments to their cars. The first picture I saw of this was in the pitlane and was willing to accept the "illusion" of the cut of the wing. However from a completely different angle, no illusion here. The right and left wing angles are not the same... and this front wing has 50% of the downforce it should have, especially with a wet track, it would have 100%.
I don't need another picture, I trust my eyes...the second elements are not the same angles...And to further the question of whether the Mclaren isn't producing enough downforce, why run 50% front downforce in the rain,when you don't have to, though this a retorical question, as I believe I do have an answer to it...IMHO
