marcush. wrote:I see that Mercedes and Mclaren are going completely differnt roads with their exhaust arrangements so I have no doubt they will not have the same power curves or top end power anyways.Installation is surely worth those 2 % or even more.Brawn had something like a 5 or even 8% bigger transmission loss in 2009 compared to Mcl and speaking of cooling packages the Macs were having excess cooling at the season opener whereas Mercedes needed to cut holes int heir ugly duck when temperatures were above what you expect in a european winter ..possibly causing a bigger power difference than you would ever find between the engines build at MHPE...it´s a nice question to ask MHPE but I don´t think it´s really important who does get the engine with that extra 10 horses....I would save the very best for the special important weekends...but surely not for Sutil or di Resta.
So are you suggesting they run a considerably different timing curve? I suppose that would make sense considering how different their cars are not to mention how different their exhausts are. That being the case, dyno numbers on a motor are not going to make a huge amount of difference as both teams are going to be looking for different characteristics in the motor regardless.
So, one makes 805bhp at 18k rpm, but has a more peaky curve in a certain rev range, while the other makes 790bhp at 18k rpm but carries a more broad and useable power curve for one's particular application, but not the other. In the end, they are both looking for different things making dyno figures almost irrelevant. Who knows, maybe Mclaren requests a specific cam timing for their motors which provides a more specific torque curve, and the same could be true for MB or FI.
