Mercedes W14
F1Krof
95
Re: Mercedes W14
Venturiation wrote:
16 Feb 2023, 13:39
Goblin42 wrote:
16 Feb 2023, 13:06
Here's a 1080p extracted video from twitter
https://video.twimg.com/ext_tw_video/16 ... mp4?tag=12
is it normal that it "stutters" or shake alot when he accelerates ? is that the misfiring?
The asphalt is wet.
Wroom wroom
Venturiation
Venturiation
101
Re: Mercedes W14
F1Krof wrote:
16 Feb 2023, 13:42
Venturiation wrote:
16 Feb 2023, 13:39
Goblin42 wrote:
16 Feb 2023, 13:06
The asphalt is wet.
like here when the car bounces a bit just before leaving the garage?
Goblin42
57
Re: Mercedes W14
Venturiation wrote:
16 Feb 2023, 13:39
Goblin42 wrote:
16 Feb 2023, 13:06
That's normal for low rev on the V6
Goblin42
57
Re: Mercedes W14
ePhil
ePhil
Re: Mercedes W14
Venturiation wrote:
16 Feb 2023, 11:53
16 Feb 2023, 11:47
Venturiation wrote:
16 Feb 2023, 11:37
he confirms the porpoising isn't caused by the exposed floor surface and the flexing floor, same for sidepods
some here will still say they are the cause
He says he doesn't believe it to be the case and I don't think it really stands as confirmation
same was said by mike eliott so who do we believe?
he said the exposed floor and sidepods aren't causing porpoising
To further back this up, Willem Toet has a good part in this lecture (about 53 minutes in) describing why porpoising occurs https://www.youtube.com/watch?v=kixMMfEQ-FA&t=3544s
Re: Mercedes W14
Goblin42 wrote:
16 Feb 2023, 13:52
From image 2: They have swapped out the louvres for a smooth panel. Makes sense given the weather & temp. Also note the sidepod with a lot of tape on it at the front. Maybe a breakage?
Venturiation
Venturiation
101
Re: Mercedes W14
they closed the BMW grill in the nose
Venturiation
Venturiation
101
Re: Mercedes W14
16 Feb 2023, 13:55
Goblin42 wrote:
16 Feb 2023, 13:52
they said they recycled many parts from last year
Re: Mercedes W14
Good view of the front wing and you can see the extra downwashing vane that kyle mentions in his analysis that is tricky to spot from other angles:
Additionally this angle gives a good look at the mid-wing. It's got a noticeably smaller section than the w13's
Re: Mercedes W14
Gonna look a mess when put through the wars, there’s no easy way to hide scars without paint, esp if they’re gonna chop & repair her often like last year.
Venturiation
Venturiation
101
Re: Mercedes W14
what are those teeth below the floor?
Re: Mercedes W14
16 Feb 2023, 13:59
https://i.redd.it/isbv54xofjia1.jpg
https://i.imgur.com/r94eTQE.jpg
https://i.imgur.com/KPQQYJD.png
Mid-wing looks swept back a fair bit too.
Re: Mercedes W14
Venturiation wrote:
16 Feb 2023, 14:10
https://pbs.twimg.com/media/FpFgL5JWAAU ... name=large
Serrations to keep the airflow attached when expanding it/changing its direction aggressively
They played around with them at the diffuser in previous regulations set, but usually only ran at tracks where efficiency was less of a concern
For instance Alfa Romeo have a serrated beam wing trailing edge this year for same reason
sbrillo
sbrillo
Re: Mercedes W14
I'm still convinced that this is not the "final" W14. And Toto Wolff seems to admit that.
Nice touch the tape on the sidepods.
fourmula1
fourmula1
Re: Mercedes W14
Can anyone speak to or link me to explanations of the mid wing shape? It is more or less unchanged. I am not aero technical. To me it looks underutilized…it seems like there could be so much more done with it? For example if all teams built the merc concept - would all the mid wings look like that due to technical regulations? Or is that really the best shape?
