Yea, the underlying issue is the race director did not following the rules. If i was Sulayem, I would have personally called Masi and canned him the first moment I had the authority to do so. He and he alone made this mess!
notsofast wrote: ↑18 Dec 2021, 20:25F1 should implement the green–white–checker finish. I'm guessing that this is what Masi was trying to simulate in Abu Dhabi. Liberty Media would probably be a proponent of such a rule change (and perhaps we as fans too). The problem is that F1 cars are fueled for the exact number of laps they need to drive. This can be fixed by requiring each car to carry, say, an additional 10kg of fuel.
https://en.wikipedia.org/wiki/Green%E2% ... ker_finish
Why do you want to extend the race though?notsofast wrote: ↑14 Jan 2022, 22:25F1 needs green-white-checkers
I meant unlapping cars should go through the crash site at SC speed. Rest of track higher speed. Pretty much this for the unlapping cars during SC period: https://www.24h-lemans.com/en/news/24-h ... work-46805 Thought that was pretty clear from that post and previous ones. Thinking of ways to shorten safety car periods in the way I've described is not rushing things or lower safety but improving efficiency. I don't understand you wouldn't want to think of ideas in that direction.PlatinumZealot wrote: ↑14 Jan 2022, 19:43Alexf1 wrote: ↑14 Jan 2022, 12:34It was done many times, and there is no problem with it. It should just be done in a safe matter. So at same speed as when SC passes that point. Wouldn't it be great if a SC period doesn't take longer than needed?El Scorchio wrote: ↑14 Jan 2022, 12:14Unlapping cars while marshals are on the track has NEVER been a thing, and for good reaso. Why should it have happened at AD?
Race cars don't unlap at the same speed as the saftey car actually. If they did they would never move away from the pack.
If a car that was unlapping has a failure it can careen off into the Marshalls and get someone killed. So I can't see why you are championing this idea.![]()
Why would it be great if the saftey car doesn't take long? Why do you want to rush a safety procedure is what I'm not understanding. Or do you mean you want the Marshalls to be able to clear the track much quicker? It is better to say this and look at ways it can be done.
But anyway this hasn't much to do adress the problem of transparency, integrity and trust in the system. It's a red herring argument.
Because imo, that line of thought is why Jules is longer with us. Back in the day drivers would push as hard as they could as often as they could. Then after years of doing that' they started pushing even when they shouldn't be, trying to gain every 0.001 seconds of advanage they could get.
Not if you make the crash site a 80 km/h slow zone (car on speed limiter). Offence is instant DQ. Also I mentioned the unlapping can only start after the crane has left the track so indeed no Jules scenario.dans79 wrote: ↑15 Jan 2022, 21:18Because imo, that line of thought is why Jules is longer with us. Back in the day drivers would push as hard as they could as often as they could. Then after years of doing that' they started pushing even when they shouldn't be, trying to gain every 0.001 seconds of advanage they could get.
If you give the teams or the drivers an opportunity to gain an advantage they will take it. The benefits are to high for them not to.
Right, and where does this slow zone begin exactly? And I do mean exactly, because the drivers will approach it at top speed, and slam on the brakes at the last possible second. Seriously, it's just a bad idea to give drivers that responsibility.Alexf1 wrote: ↑15 Jan 2022, 21:45Not if you make the crash site a 80 km/h slow zone (car on speed limiter). Offence is instant DQ. Also I mentioned the unlapping can only start after the crane has left the track so indeed no Jules scenario.dans79 wrote: ↑15 Jan 2022, 21:18Because imo, that line of thought is why Jules is longer with us. Back in the day drivers would push as hard as they could as often as they could. Then after years of doing that' they started pushing even when they shouldn't be, trying to gain every 0.001 seconds of advanage they could get.
They don't have to, they've got almost 2 laps to reach the back of the pack which is driving a minute a lap slower than race speed. If this is such a bad idea why are they using it at Le Mans. Works just fine.cooken wrote: ↑15 Jan 2022, 23:12Right, and where does this slow zone begin exactly? And I do mean exactly, because the drivers will approach it at top speed, and slam on the brakes at the last possible second. Seriously, it's just a bad idea to give drivers that responsibility.Alexf1 wrote: ↑15 Jan 2022, 21:45Not if you make the crash site a 80 km/h slow zone (car on speed limiter). Offence is instant DQ. Also I mentioned the unlapping can only start after the crane has left the track so indeed no Jules scenario.dans79 wrote: ↑15 Jan 2022, 21:18
Yea, and they are doing basically the same thing now under the virtual safety car. They go way faster in certain segments of the mini sectors, to warm their tires, or just to gain on their competition in hopes of the the vsc ending at just the right spot.cooken wrote: ↑15 Jan 2022, 23:12Right, and where does this slow zone begin exactly? And I do mean exactly, because the drivers will approach it at top speed, and slam on the brakes at the last possible second. Seriously, it's just a bad idea to give drivers that responsibility.Alexf1 wrote: ↑15 Jan 2022, 21:45Not if you make the crash site a 80 km/h slow zone (car on speed limiter). Offence is instant DQ. Also I mentioned the unlapping can only start after the crane has left the track so indeed no Jules scenario.dans79 wrote: ↑15 Jan 2022, 21:18
They don't have the same issues at Le Mans. An F1 Driver will push as hard as they can get away with, because tires and brakes thats are up to temp, is a much larger advantage than in other series!Alexf1 wrote: ↑16 Jan 2022, 00:42They don't have to, they've got almost 2 laps to reach the back of the pack which is driving a minute a lap slower than race speed. If this is such a bad idea why are they using it at Le Mans. Works just fine.
Red flag it instantly. All cars in pit. No tyre change allowed. Rolling start when white flag is shown. Much easierAlexf1 wrote: ↑15 Jan 2022, 13:09I meant unlapping cars should go through the crash site at SC speed. Rest of track higher speed. Pretty much this for the unlapping cars during SC period: https://www.24h-lemans.com/en/news/24-h ... work-46805 Thought that was pretty clear from that post and previous ones. Thinking of ways to shorten safety car periods in the way I've described is not rushing things or lower safety but improving efficiency. I don't understand you wouldn't want to think of ideas in that direction.PlatinumZealot wrote: ↑14 Jan 2022, 19:43
The second marshall post prior to the incident site and second marshall post after the incident sitecooken wrote: ↑15 Jan 2022, 23:12Right, and where does this slow zone begin exactly? And I do mean exactly, because the drivers will approach it at top speed, and slam on the brakes at the last possible second. Seriously, it's just a bad idea to give drivers that responsibility.Alexf1 wrote: ↑15 Jan 2022, 21:45Not if you make the crash site a 80 km/h slow zone (car on speed limiter). Offence is instant DQ. Also I mentioned the unlapping can only start after the crane has left the track so indeed no Jules scenario.dans79 wrote: ↑15 Jan 2022, 21:18
