The same rule as is in place in 2012 occurs.
However, the front bulkhead has a max height limit of 525mm above the reference plane.
so no rule on nose tip then? In that case, my nose meets regs,Tozza Mazza wrote:The same rule as is in place in 2012 occurs.
http://scarbsf1.com/blog1/2012/10/01/20 ... n-changes/N12ck wrote:so no rule on nose tip then? In that case, my nose meets regs,Tozza Mazza wrote:The same rule as is in place in 2012 occurs.
However, the front bulkhead has a max height limit of 525mm above the reference plane.![]()
I now know that, if you look, I posted that long ago hahabucker wrote:http://scarbsf1.com/blog1/2012/10/01/20 ... n-changes/N12ck wrote:so no rule on nose tip then? In that case, my nose meets regs,Tozza Mazza wrote:The same rule as is in place in 2012 occurs.
"As part of the safety programme the FIA will introduce much lower noses. The nose tip must be centered around 185mm and the front bulkhead lowered to 500mm."
What about the tyre wars of 2001-2006. I remember that Montezemolo said it was a tyre championship and not about the cars at all. So it can't have been all about aero. And engine power was also something that mattered before the freeze.FoxHound wrote:.. cars of the last 25 years that have gone on to win, have been the best aerodynamically.
If we're moving away from aero dependence, then I say go whole hog and get back to Cigar Cars. What's the pinnacle of motorsport if you take away the tools to get there?FoxHound wrote:I believe the idea is to move away from aero dependance.
Generally speaking, cars of the last 25 years that have gone on to win, have been the best aerodynamically.
This rule set is a small attempt at redressing the balance.
Wouldn't you want to do that? Drive all 6 headers into one turbo to maximise your boost gains?mx_tifoso wrote:GP2 style center exiting exhausts!?![]()
WhiteBlue wrote: What about the tyre wars of 2001-2006. I remember that Montezemolo said it was a tyre championship and not about the cars at all. So it can't have been all about aero. And engine power was also something that mattered before the freeze.
