Will the complex frontal aero wings be gone?
HOW do you think raised?Tozza Mazza wrote:There's also a new survival cell shape, we'll see a nose height limit at the tip imposed, and skinnier rear wings.
I was not under the impressions front wings were being raised at all, must have missed it!
Do you have that article number ESP?
As in Le Mans style?Both pedals will have to work in full dual mode. It means that the throttle pedal will simultaneously control the engine and the MGUK.
Nothig has been confirmed as of yet, however Pirelli have been told to prepair for one in 2014 at the earliest. However wheels are widely belived to be changing for 2015 when there is a rumor that there will be a second tire supplyer and new tyre rule as well where the length of distance a compound can go will be specified by the FIA, where there will be 3 compounds for each supplyer that will go to each event.WhiteBlue wrote:There is nothing in the rules that suggest the wheels will be changed.
What has the wheel diameter got to do with V-max? Even the tyre diameter is of (from a ratio point of view) no effect once the gearbox ratios are adjusted. V-max only really depends on tractive power and aerodynamic drag.ESPImperium wrote:The increase in wheel size means that V-Max will be higher and the cars will be slower into corners, probably taking as much as 15kph off some of the faster corners, thus goading drivers into pushing the cars to the limit, thus more mistakes and with a higher V-Max, more overtaking at points you wouldnt think.
I would bet if a team decided to run a 4 wheel drive/steering system, they could use it and say the regs allow it.allstaruk08 wrote:"1.2 Automobile :
A land vehicle running on at least four non-aligned complete wheels, of which at least two are
used for steering and at least two for propulsion"
does that mean you can have 4 wheel drive and 4 wheel steer?
