So they are carrying more than 100kg of fuel when they leave the pits, roughly how much would they need to carry?turbof1 wrote:You have to make a distinction between the2:
-The fuel rate applies at any given moment: so you aren't allowed during a given time moment A to spend more fuel then 100kg/h, 1,66kg/m, 27.778g/s,... .
-On top of that, you aren't allowed to spend more then 100kg of during an entire race (start to chequered flag).
What does that mean? Well the first is better to be looked at as the peak fuel consumption rate. It is expressed in kg/h, but isn't about what you are allowed to spend in a hour, but a fuel rate you are never allowed to go above. It might be a bit clearer if you take as grams per second. It's still the same rate though.
The second is your maximum consumption from the start of the race (the moment the green lights turn on) to the crossing of the chequered flag. So it doesn't matter if the race is a hour, 1.5 hours, 2 hours,... . You have 100kg to do that. Do note this does not include installation laps, formation lap, in lap after crossing the flag and fuel sample.
https://twitter.com/nh247/status/445147201879429120Ultra_Tech wrote:I have another question, Adam Cooper has said that the teams were told the only mitigating circumstances for violating this rule was a faulty FIA sensor.basti313 wrote:The fuel flow sensors are double checked with the fuel consumption calculated by the McLaren standard ECU because the standard ECU still is more precise than the fuel flow sensor. This was announced before the race.Ultra_Tech wrote:How can red bull get away with anything. Whatever the circumstances, if they gained a performance advantage by going over the agreed limit, then they have to be sanctioned.
Am I right when it seems that Red Bull changed the sensor in Parc Ferme this weekend?
Let me know because if so and that is the case, i consider that highly suspect that a team would do that, almost as if they were planning to exceed the limit and then use the faulty sensor arguement as a backup.
I dont know if this is the case....just going on some chatter online?
How would that not be the same?feni_remmen wrote:I guess they are currently aurguing that 100kg/hour is not the same as 50 kg/30 minutes... Different to 25 kg/15 minutes too... 1.67 kg /minute anybody?
I posted this info 4 minutes before this tweet, top of last page. Hi Nick!thomin wrote:https://twitter.com/nh247/status/445147201879429120
No, if I understood it correctly the problem is that the flow meter sets a flag if the flow exceeds the allowed value for 1/10 second.feni_remmen wrote:I guess they are currently aurguing that 100kg/hour is not the same as 50 kg/30 minutes... Different to 25 kg/15 minutes too... 1.67 kg /minute anybody?
The rules are written as to not allow a fuel flow of over 100kg/h at any given time, so it's specified as "in every instant", not "30 minutes over and then 30 minutes under". However since in practical terms you cannot measure "in every instant" they have decided to use a certain sampling frequency. On the previous page someone mentioned it is 5 readings / second. So basically the practical fuel-flow limit is 5.56 gram/ 0.2 sec, since that's the window they are policing.pyrosian wrote:If you used 100kg in 30 mins and nothing for the next 30mins your fuel flow is 100kg an hour is it not?
Rules dictate 100kg/h as maximum rate of fuel flow, you can't go over that not even for a second (at least you are not suppoused to), doesn't matter if you ran with less than that the rest of the time.pyrosian wrote:If you used 100kg in 30 mins and nothing for the next 30mins your fuel flow is 100kg an hour is it not?
If you did 100mph for 5 minutes and stopped for 5 minutes would that reduce you maximum speed to 50mphpyrosian wrote:If you used 100kg in 30 mins and nothing for the next 30mins your fuel flow is 100kg an hour is it not?
Where did you get that?NTS wrote:The rules are written as to not allow a fuel flow of over 100kg/h at any given time, so it's specified as "in every instant", not "30 minutes over and then 30 minutes under". However since in practical terms you cannot measure "in every instant" they have decided to use a certain sampling frequency. On the previous page someone mentioned it is 5 readings / second. So basically the practical fuel-flow limit is 5.56 gram/ 0.2 sec, since that's the window they are policing.pyrosian wrote:If you used 100kg in 30 mins and nothing for the next 30mins your fuel flow is 100kg an hour is it not?
