Looks like Ricciardo will get DSQ'd...
http://www.autosport.com/news/report.php/id/112953
Unless they can prove the fuel rate meter was malfunctioning, this pretty much looks like a black 'n white case.
What is the penalty for that? Automatic DSQ or a possible time penalty?thomin wrote:That doesn't look good for him...I really wonder how Red Bull could commit such an error...? If the FIA was able to tell that he "consistently" exceeded the fuel limit, then so was Red Bull. A sensor issue therefore seems highly unlikely. Of course I'm speculating here, I'll be interesting to hear Red Bull's explanation.NathanOlder wrote:Ricciardo under investigation
http://www.f1fanatic.co.uk/2014/03/16/r ... t-breach/?
That is interesting, thanks for pointing that out. I do tend to compare the stats that show success/fail, which means wins/poles/retirements, rather than per race, but that is also quite interesting. In that context you could say he is pretty lucky compared to many drivers, which seems to be counterintuitive.mnmracer wrote: Yeah, overall he has had 17 retirements, but that alone doesn't say anything without understanding what happened to other drivers.
Hamilton has had 17 retirements from 130 starts, or 13%.
Alonso has had 33 retirements from 218 starts, or 15%.
Vettel has had 19 retirements from 122 starts, or 16%.
Button has had 48 retirements from 251 starts, or 19%.
Räikkönen has had 44 retirements from 195 starts, or 34%.
Retirement-wise, Hamilton's got the best score from all the champions.
One would think that an automatic DSQ would be in order, especially after declaring a hard stance on the issue before the race. On the other hand, if there was some sort of malfunction by a FIA specified part, then there might be no consequence. I remember Alonso getting off without penalty despite using DRS when he wasn't legally permitted to do so.mnmracer wrote:What is the penalty for that? Automatic DSQ or a possible time penalty?thomin wrote:That doesn't look good for him...I really wonder how Red Bull could commit such an error...? If the FIA was able to tell that he "consistently" exceeded the fuel limit, then so was Red Bull. A sensor issue therefore seems highly unlikely. Of course I'm speculating here, I'll be interesting to hear Red Bull's explanation.NathanOlder wrote:Ricciardo under investigation
By not using fuel at a rate of 100kg per hourGaara wrote:So they are allowed 100 kg per race right? the race is 1.5 hours. How the drivers should not pass the 100kg/hour limit?
Indeed, 100 kg/hour is the maximum they can go.NathanOlder wrote:By not using fuel at a rate of 100kg per hourGaara wrote:So they are allowed 100 kg per race right? the race is 1.5 hours. How the drivers should not pass the 100kg/hour limit?
I'm not entirely sure about this, but I seem to remember that at least parts of the fuel injection system are specified by the FIA in order for them to be able to monitor it and to prevent teams from cheating. If there was a malfunction in that specific part, then it would be very difficult to punish Red Bull for it. But I admit that I'm reaching here...AlexJ wrote:If I remember that incident Alonso's DRS popped open during a turn, so he got off on the grounds of not having gained an advantage.thomin wrote:One would think that an automatic DSQ would be in order, especially after declaring a hard stance on the issue before the race. On the other hand, if there was some sort of malfunction by a FIA specified part, then there might be no consequence. I remember Alonso getting off without penalty despite using DRS when he wasn't legally permitted to do so.
Exceeding the permitted fuel usage even by accident is unlikely to be considered the same way.
Could Red Bull have just ignored that? I mean I can see how it could have happened: They saved a lot of fuel at the beginning due to the second warm up lap and the safety car, so they could afford to use more than 100kg/h later without exceeding the overall 100kg limit. But that seems to be a very stupid mistake to make...mikeerfol wrote:Indeed, 100 kg/hour is the maximum they can go.NathanOlder wrote:By not using fuel at a rate of 100kg per hourGaara wrote:So they are allowed 100 kg per race right? the race is 1.5 hours. How the drivers should not pass the 100kg/hour limit?
