That's different though, using the wrong engine map is detrimental to the team and the driver, because the driver could burn up the motor. The only thing I can see potentially being negative about under fueling the car, is the chance of running out, everything else is a positive!Phil wrote:dans79 wrote: For the same reason they obviously don't want one driver using a different engine map than the other. There's heaps of evidence for this - the spat in Bahrain (where Rosberg apparently used a different engine map) and in a later race, when Hamilton repayed the favour (China?).
Delta was about 1kg in Monza throughout the race but that could be track specific.““So there are times when Nico is ahead and I’m able to see those things. And there are times when I’m ahead and he’s able to see it. For example the fuel usage. After the last race they found out how I’m saving fuel and he’ll be aware of that now and maybe he’ll be a lot closer on fuel usage.”
http://www.jamesallenonf1.com/2014/07/h ... this-year/
Sounds a bit on the high side if you ask me.According to Mark Hughes they put less fuel into Hamitons car. It varies from track to track depending on the usage – at Bahrain, for instance, Mr Hughes reckons Hamilton had as much as 8.75kg less fuel than Rosberg at the start of the race.
Hm, not sure. Probably that one. It was hamilton who said this tbh, that's why i was going with it. It does seem the car infront is way too ahead and rosberg just nailed that 1st chicane, giving him lots of time.SectorOne wrote:Is that the lap shown on F1.com onboards?Juzh wrote:It came to light ros had a car infront of him on his last lap, so he was faster in speed trap and s1. Whether the car infront let him past or not after that is not clear. im pretty sure they ran identical cars though.
Because he has a car ahead of him on that lap but it´s so far ahead of him i doubt it had much of a significance.
No you haven't understood it correctly. The car doesn't necessarily need fuel to run in a corner. It uses fuel under throttle application. There will be parts of the corner that throttle is used while others parts not. Obviously throttle will be used to accelerate out of the corner, and also to balance the car in the corner if it's required but brake can also be used to balance the car depending on the corner, the car setup the driving style etc. You are oversimplifying by assuming he would have to be on the throttle earlier to make up the lap time. He could in fact be simply carrying more speed into the corner, through the corner and hence having to apply less throttle on exit.iotar__ wrote:It's probably me but the way it was described I imagined it like this: Hamilton can lift and coast at the end of the straight saving fuel like no one else, then (and this is important part) he's making up the lost time in corners which oversimplifying would mean to be on the throttle earlier than everybody else (how else?), this damn car needs fuel to run whether it's a corner or a straight . I imagined fast corners and Red Bull 10-13.
They can't say that anymorePlatinumZealot wrote:I will not be surprised if Rosberg is told to save fuel in this race.
They can if it's for reliability reasonssiskue2005 wrote:They can't say that anymorePlatinumZealot wrote:I will not be surprised if Rosberg is told to save fuel in this race.
http://www.formula1.com/news/headlines/ ... 16349.htmlMessage types not allowed
- Sector time detail of a competitor and where a competitor is faster or slower.
- Adjustment of power unit settings.
- Adjustment of power unit setting to de-rate the systems.
- Adjustment of gearbox settings.
- Learning of gears of the gearbox (will only be enforced from the Japanese Grand Prix onwards).
- Balancing the SOC [state-of-charge of batteries] or adjusting for performance.
- Information on fuel flow settings (except if requested to do so by race control).
- Information on level of fuel saving needed.
- Information on tyre pressures or temperatures (will only be enforced from the Japanese Grand Prix onwards).
- Information on differential settings.
- Start maps related to clutch position, for race start and pit stops.
- Information on clutch maps or settings, e.g. bite point.
- Burn-outs prior to race starts.
- Information on brake balance or BBW (brake-by-wire) settings.
- Warning on brake wear or temperatures (will only be enforced from the Japanese Grand Prix onwards).
- Selection of driver default settings (other than in the case of a clearly identified problem with the car).
- Answering a direct question from a driver, e.g. "Am I using the right torque map"?
- Any message that appears to be coded
You can be reasonably assured that when the car runs out of fuel, it will cease to run. You wouldn't rely on it to finish without any fuel, thus it is less reliable.siskue2005 wrote:What reliability problem can be justify a save fuel comment??
Ah, "reliability reasons", you can do a lot of things with that xcuse.mikeerfol wrote:They can if it's for reliability reasonssiskue2005 wrote:They can't say that anymorePlatinumZealot wrote:I will not be surprised if Rosberg is told to save fuel in this race.
