What will be the weight penalty using Alu for gearbox case?scarbs wrote:Another question for Williams aside its low set gearcase, will be the continued use of the cast alumnium gearcase. Prhaps it will move to Carbon or Ti ?
I would have thought aluminum wouldn't have been stiff enough on such a long object and if they used extra material that it would be to heavy.scarbs wrote:Yes cast Alu. never heard of forgings being used for F1 cases .trinidefender wrote:Was it ever confirmed that the gearbox is actually cast aluminum? Would a forging with further machining not be lighter and stronger, assuming of course they will be able to create the shapes required through forging?scarbs wrote:Another question for Williams aside its low set gearcase, will be the continued use of the cast alumnium gearcase. Prhaps it will move to Carbon or Ti ?
Secondly are we sure it is in fact aluminum? If you can say with certainty that it is then I won't have a problem believing you, just was there any actual confirmation?
In our helicopter (and many others) the gearbox casing is made out of a magnesium alloy for its combination of lightness and strength.
trinidefender wrote:I would have thought aluminum wouldn't have been stiff enough on such a long object and if they used extra material that it would be to heavy.scarbs wrote:Yes cast Alu. never heard of forgings being used for F1 cases .
That's why I asked for confirmation if it is in fact aluminum and not a magnesium alloy or some other metal alloy casing.
Can anybody with metal specialties advise me if a magnesium alloy casing would be viable?
That can be reduced by alloying with calcium, dysprosium and/or yttrium, without affecting too much the mechanical properties.livinglikethathuh wrote:Magnesium's flammability may also be a concern.
Did they not use the same style case as Mercedes? It was an aluminium cartridge that slots into a CF housing. This means they can make loads of changes to suspension geometry without making any changes to the gearbox itself.LookBackTime wrote:What will be the weight penalty using Alu for gearbox case?scarbs wrote:Another question for Williams aside its low set gearcase, will be the continued use of the cast alumnium gearcase. Prhaps it will move to Carbon or Ti ?
When I first started flying a helicopter with a magnesium gearbox casing I actually asked the same question. In the 30 something years that this type has been flying I don't know of any gearbox fires to have taken place. Even with the rotor system disk brake placed on the casing. I would think if it can be approved for the super conservative world of aviation it could work in f1, assuming it is desireable of course.3jawchuck wrote:That can be reduced by alloying with calcium, dysprosium and/or yttrium, without affecting too much the mechanical properties.livinglikethathuh wrote:Magnesium's flammability may also be a concern.
A magnesium gearbox casing skidding on the ground after a wheel/suspension failure is what frightens me. The sparks and the casing itself could catch fire that way quite easily.trinidefender wrote:When I first started flying a helicopter with a magnesium gearbox casing I actually asked the same question. In the 30 something years that this type has been flying I don't know of any gearbox fires to have taken place. Even with the rotor system disk brake placed on the casing. I would think if it can be approved for the super conservative world of aviation it could work in f1, assuming it is desireable of course.3jawchuck wrote:That can be reduced by alloying with calcium, dysprosium and/or yttrium, without affecting too much the mechanical properties.livinglikethathuh wrote:Magnesium's flammability may also be a concern.
No Williams has their own gear box. Made from Alu.SiLo wrote:Did they not use the same style case as Mercedes? It was an aluminium cartridge that slots into a CF housing. This means they can make loads of changes to suspension geometry without making any changes to the gearbox itself.LookBackTime wrote:What will be the weight penalty using Alu for gearbox case?scarbs wrote:Another question for Williams aside its low set gearcase, will be the continued use of the cast alumnium gearcase. Prhaps it will move to Carbon or Ti ?
If they start buying from Mercedes then they either pay some of their specialized gearbox staff to sit around doing nothing (or at least much less) or they let the staff go and lose the ability to create the most difficult chassis component of the car. A potentially dangerous loss of internal ability and therefore independence.LookBackTime wrote: No Williams has their own gear box. Made from Alu.
Two years ago was a discussion if they should buy the Mercedes gear box. For Aero reasons they decline at that moment in time. May be this year is better to just buy the Mercedes one
please elaborate, how is and what is an aluminium engine encased in a magnesium alloy ?? (and which model ??)PlatinumZealot wrote:BMW engines since the mid 2000's have been Aluminum encased in a Magnesium Alloy.... No fires..
Magneisum is stiffer and lighter.
I think Lotus used a titanium gearbox for a few years.. Titanium is heavier than Al but it is stiffer. So it all about what the skill of the designer with the different materials.
People keep stating that the gearbox was aluminium but are we really sure. I mean has Williams ever actually stated that it was aluminium or have people just seen what it looks like and the colour and assumed aluminium and then that idea stuck?bill shoe wrote:If they start buying from Mercedes then they either pay some of their specialized gearbox staff to sit around doing nothing (or at least much less) or they let the staff go and lose the ability to create the most difficult chassis component of the car. A potentially dangerous loss of internal ability and therefore independence.LookBackTime wrote: No Williams has their own gear box. Made from Alu.
Who among the non-manufacturer teams still makes their own box?
McLaren (but really a manufacturer team)
Lotus/Renault (same)
Red Bull (same)
Williams (true independent)
And who does not make their box?
Force India
Sauber (not sure)
Manor
Toro Roso
The source of your box does not directly change you from one group to the other, but it plays a role...
