It’s actually the opposite. Bio-fuels and synthetic fuels are much more attractive in both customer cars and in the F1 application - just look at the facts. One already has the infrastructure in place, the cars can readily be converted to these new sustainable fuels without any effort and they don’t leave a carbon footprint to produce unlike the batteries which also can’t be recycled.DChemTech wrote: ↑18 Dec 2020, 17:40It's all just talk to try and defend a botched route. As JAF indicates, the door to full electric is closed essentially, so they have to find an alternative and try to hype that. Doesn't mean it's actually a good alternative. Biofuels and Synfuels are just not that attractive for customer car applications. By far most commuting can be done with electric vehicles viably, and as battery tech develops, that range just extends. ICEs may have a longer life in medium/long-range transport, especially heavy transport, but there the link to F1 development is less direct, and with fuel cells, there are upcoming alternatives.RedNEO wrote: ↑18 Dec 2020, 15:53RedNEO wrote: ↑18 Dec 2020, 15:49Domenicali is also saying the same as Toto that F1 is shifting its focus away from electric onto sustainable synthetic/bio fuels..
https://v6dsseewh55yamhdvpyc6idqzq-adwh ... i/4928933/
This is the perfect opportunity for F1 to show you can have a high revving screaming engine that’s run on sustainable fuels with a virtually non existent carbon footprint unlike the production of batteries
And sure, batteries take energy to produce, but battery tech improves (reducing energy input in production) ánd the used energy becomes ever more green. Also, biofuel takes quite some energy to produce, so a similar argument is applicable there. And what's more, there's only so much biomass to go around - way insufficient to fulfill the entire transportation market. Biofuels may have their niche-applications in areas where energy density is crucial (aviation), but aside from that, there are better alternatives. When it comes to SynFuel, there seems to be little incentive (aside from being able to use current infrastructure) to go to higher hydrocarbons which require a lot of C-C bonds to be made, and additional process steps generally go at the cost of efficiency of the storage cycle. So why bother? Use green energy to produce hydrogen, and use that directly - you can put it in a fuel cell, and storage is not really an issue in fields of decently predictable demand (e.g. transport). In fields where demand is more variable so medium/long-term storage is desired, or where a higher energy density is required, add one CO2 to create methanol or formic. Liquid, so easy to store, and again fuel-cell ready (with all due benefits in toxic/particulate emissions, too).
If you want to go for a series that's future tech relevant, either get a deal with FE or go for fuel cell tech. If you want noisy ICEs, fine. But then accept that it's going to be an entertainment sport, and don't pretend it's about tech development.
We have all read the numerous papers that say EVs will not reduce the carbon footprint. It will make it larger because, fundamentally an EV can not cover the lifespan of a fuel based vehicle where the benefit can be achieved. It takes around 3x the mileage life of a fuel based car to get any net benefit. Batteries simply don’t have an answer to compete with sustainable fuels and will not have the infrastructure in place to be able to pose any serious threat in the car industry. With F1 and the manufacturers backing its just going to get harder for batteries to compete with this, it’s over.
