Ian P. wrote:
Yes they will cut it back to reduce drag on the straights, yes they will go full-wing for the brakeing zone. How long they leave the wing in that position will depend on the configuration of the track.
Example, Indianapolis, US GP (someday again we hope...)
Main straight... 0 deg
Braking zone... 6 deg
Twisty bits ... 4 deg (this gives you 2 deg to play with for balance adjustment)
Entrance to last corner...no change
Last corner (Ralph's favourite) drop to 0 deg after apex.
Two changes per lap. Job done.
Once the teams figure the optimal way to use the system and the FIA finds they have been had, then the rule limitations will start.
That is obviously more than 2 changes per lap... did you lose count as you were typing that?
Not that I would admit to loosing count....I was just thinking like an Italian team would.
Base wing position ... 0 deg
Change at the end of the main straight to 6 deg or so.
Return to 0 deg....net one adjustment.
Entering the twisty bits, set to ....4 deg
Return to 0 deg...net second adjustment.
If you adopt the (somewhat logical) approach that 0 to 6 and back to 0 deg is two changes, then you are really only getting one adjustment per lap. Seems straight forward but not what I understood was intended.
It will be interesting to see how this works out. Could be some interesting interpretations on what would seem to be a really simple concept.
Personal motto... "Were it not for the bad.... I would have no luck at all."
