There are two pipelines, upper one fed by air, and lower one as you can see attached to airbox.
n_anirudh posted this pic in another topic, here is the enhanced version.
Look like they have system that does both blowing and sucking simultaneously.
I see what you did therePandamasque wrote:So far it seems to suck mostly. Otherwise they would keep it for the race.
Randy Mandy definitely has some skills up her sleeve! Luscious Liz couldn't suck nor blow.manchild wrote:...
You know, F1_eng, comments like the one above are not constructive. They simply make a statement about you (with apologies).F1_eng wrote:Absolutely lacking in any basic technical knowledge or common sense.
=D> =D> =D>DaveW wrote:You know, F1_eng, comments like the one above are not constructive. They simply make a statement about you (with apologies).F1_eng wrote:Absolutely lacking in any basic technical knowledge or common sense.
Forums like this are sometimes entertaining, sometimes revealing &, just occasionally, contain brilliant ideas. By all means read them & draw your own conclusions, but I would suggest that you contribute only with constructive comments. I recall, years ago, hearing one very senior technical person in F1 observe that if 10 percent of ideas (from F1 engineers) actually worked, then they were in good shape. I can't think much has changed in that respect.
Looks more like RB are blowing the boundery layer to increase DF on one and blowing the slot with the other.manchild wrote:Holly s*** RB has something similar.![]()
Slit could by no means reduce the pressure on top surface. I had im mind effect of suction as somthing that would change behavior or air flow over top surface.F1_eng wrote:Absolutely lacking in any basic technical knowledge or common sense.
If you attempt to couple low airbox pressure to the top of the wing, you simply lower the Cp, simple. Lowering top surface Cp reduces net pressure differential, less downforce.
There are other basic flaws such as the assumption of airbox pressure variation.
Afraid its not a good idea in any sense.
The important thing is Manchild had and idea and shared it. Be it feasible then COOL! and if not, others can build from it or can help Manchild to rethink about it and show its faults to finally achive some conclusion.marcush. wrote:=D> =D> =D>DaveW wrote:You know, F1_eng, comments like the one above are not constructive. They simply make a statement about you (with apologies).F1_eng wrote:Absolutely lacking in any basic technical knowledge or common sense.
i like floating around ideas
I'm not a pro so I couldn't give you formulas better than this one.F1_eng wrote:"Think of it as take vacuum cleaner's suction nozzle at certain angle, pointed in direction of car's movement. It would decrease drag and prevent air from slipping as more air would constantly hit top surface."
I'm not sure what you are trying to say, can you explain it with some formulas or numbers or what the basis of the principal is?
Exactly, but since I'm not a pro I didn't dare to mention boundary layer. I think this would if not eliminate it than significantly reduce it, and increase wings performance, especially on low DF circuits.F1_eng wrote:What is the effect and how? Are you looking at boundary layer extraction?
