I was thinking... ram-air effect that feeds the blown wing is immeasurably lesser that what inverted functioning would be. Ram-air generated pressure/volume/speed depends on inlet diameter and the speed of car, while sub-pressure of sucked tube depends on capacity of suction device - in this case the engine.
It would even rise as speed decreases and so do revs, right?
So, what I'm recommending would be instead of blowing wing trough aperture at the back, there should be aperture on wing's top connected to airbox. Siphon shape would prevent the air stream from entering duct, and simultaneously direct sucked air in direction of main air stream.
Since engine revs are much more constant than speed of the car, this would be more effective on any part of the circuit.
*This is just a quick sketch, had no time to think how Mclaren's airbox looks like.
