wrcsti wrote:In a dream a couple of nights ago (i have lucid dreaming)
hehehe I also have such dreams.
Once I dreamed of a very good way to do brackets for your FSAE team. Right on the next day I changed the old ones to the new design and we used them on the car.
Its funny that I had to dream of it to solve a problem I was not able to solve during several weeks.
So in fact it is possible to develop things when you sleep.
I thought of a way to make an RC car suspension which was completely customisable in every sense of movement and very easy to tune. I tried making a drawing but failed at it but it is essentially 3 arms, which have adjustable lenght, placed 2 in the bottom and 1 on top of the upright. The 2 on the bottom can control track width and toe while the one on top can control camber and caster depending on were it is mounted. For the actual suspension right were the top one is mounted have a spring runing to where the lower ones are mounted on the chasis itself. It might need a mit of movement to clear the dogbones but the idea itself is very doable and pretty cheap if you have a hobbyshop with all the required parts at hand.
Basically this sounds like a double wishbone suspension.
Actually you have 3 rods there, 2 wishbones and one track rod controlling toe.
