Scuderia Ferrari SF70H
WaikeCU
Re: Scuderia Ferrari SF70H
Sevach wrote:
Just_a_fan wrote:Compared to the simplicity of RedBull's diffuser and Mercedes's relatively simple diffuser in this area makes me think that Ferrari have got themselves in to a bit of a loop here. Of course the teams have their own aero strategies which lead to different design solutions but...simpler is always the better option if it works.
Last year the FW and the stuff under the nose wasn't complex enough, "a generation behind", now the diffuser is too complex...
Are you trying to say that being too complex, there's not enough space to further develop, because it's already too complex?
Mr.G
34
I think he was ironic to all the people who last year said "Last year the FW and the stuff under the nose wasn't complex enough, a generation behind", and now they say "the diffuser is too complex..." just because it's not W08 but SF70H...
Not at all, just a comment on armchair specialists.
matt_s
matt_s
Just a note. My original post that started the complexity discussion was merely an observation that Ferrari seemingly have an order of magnitude more flaps and turning vanes than anyone else. Not that it's better or worse, but it's certainly in marked contrast to the RB13 which is extremely simple. However I would be very surprised if the RB was lacking diffuser performance.
tpe
tpe
-4
Mr.G wrote:
Does anyone have some info about the strip in the floor and why they measuring the temperature there? I found only some speculations. From them the most reliable seem to be piping for the gearbox cooling...
Here is another speculation: Cables from/to batteries.
Worried for Ferrari here. This is the opposite of redbull philosophy which is to start simple and understand the flows then upgrade from there. Ferrari has started with very complex mechanisms... Do they understand them already? Will the upgrade path be less painful than last year? I hope so.
Mr.G
34
Cables to where? MGU-K/H are mounted to the ICE...
Big Mangalhit
27
They better it is completely in line with last year's diffuser with only a few additions, which I think were even brought during the course of this year testing.
Ferrari Nose and S-Duct:
ScrewCaptain27
577
- Serj Tankian
tpe
tpe
-4
Mr.G wrote:
tpe wrote:
Mr.G wrote: Does anyone have some info about the strip in the floor and why they measuring the temperature there? I found only some speculations. From them the most reliable seem to be piping for the gearbox cooling...
Break by wire.
Again, just a speculation.
Yes, that's the function of the MGU-K...
Maybe they've got some coolant/oil hoses under the floor there rather than in the sidepod, but if they are it'd be a strange route, unless they're hydraulic oil from the rear dampers to the accumulator in the sidepod.
ripper
ripper
39
New Ferrari RW
taken from http://www.f1analisitecnica.com
Fede90
Fede90
I have another idea...maybe and i say, maybe...the relatively simplicity of RB's diffuser can be compensated by new and discussed suspension with the "hydraulic work". Let me use this word.
When you have a great system that can change the hight from the ground, do you need a complex diffuser that give you more downforce?
imho.
