Aston Martin AMR24
mwillems
45
Re: Aston Martin AMR24
-Bandit
quincalla
quincalla
First time this year they are running any louvers on the engine cover.
Also the way the DRS flap merges with the rest of the RW structure is new isn't it?
They've moved away from the separate top element which most teams have moved towards and separated/cutout second element was visible on the same wing (?) at Saudi
Miami showing merged corner
Same wing (?) at Saudi showing cutout/separated top element
wiktor977
wiktor977
quincalla wrote:
02 May 2024, 22:22
Is Miami hotter than other tracks they have been this year? I'm not 100% sure but I will say no. Maybe they are running a smaller 'coke bottle' cooling exit.?
Ashwinv16
wiktor977 wrote:
02 May 2024, 22:49
quincalla wrote:
02 May 2024, 22:22
Temperatures about 25*C, highest so far so makes sense and I noticed the coke bottle region is smaller and more downward slopped as well.
Halo not as bad as we thought
quincalla
quincalla
02 May 2024, 22:48
https://i.imgur.com/403btcC.jpeg
https://i.imgur.com/hqeyS61.jpeg
I think it's this one from Bahrain (the mainplane of the one from Jeddah is more curved), but agreed on the rest.
quincalla wrote:
03 May 2024, 00:58
02 May 2024, 22:48
That Bahrain one has a v cutout in the flap behind the DRS actuator.. a new wing entirely?
quincalla
quincalla
03 May 2024, 01:01
quincalla wrote:
03 May 2024, 00:58
02 May 2024, 22:48
Good eye! Also the distance from the actuator to the top flap is very different. It's either completely new or frankensteined from the Bahrain wing.
quincalla wrote:
03 May 2024, 01:13
03 May 2024, 01:01
quincalla wrote:
03 May 2024, 00:58
The endplates, or where we used to have endplates, are much longer. Bahrain is high DF, the angle of attack of this rear wing looks at about 130 degrees, while Bahrain's was between 95 and 105 degrees.
quincalla wrote:
03 May 2024, 00:58
02 May 2024, 22:48
https://i.imgur.com/hq4eXq4.jpeg
Good compares? Can see the angel of attack in this pic.
vs
diffuser wrote:
03 May 2024, 14:36
quincalla wrote:
03 May 2024, 00:58
02 May 2024, 22:48
https://pbs.twimg.com/media/GMmY57eWsAA ... ame=medium
vs
Maybe just a new DRS flap + endplate corner. Main plane looks same to me
-wkst-
-wkst-
Miami
Saudi Arabia - Bahrain
Bahrain
03 May 2024, 14:42
diffuser wrote:
03 May 2024, 14:36
quincalla wrote:
03 May 2024, 00:58
vs
The main plain, in this case doesn't do much. It's mainly flat, with a bit of a U shape. The biggest difference is the endplate corners and the angel of attack of the actual wing that opens for DRS.
Luscion
Luscion
113
Hard to find good pics on the web these days ... Thank god for AMUS!
They didn't have a pic of the new beam wing ... :(
