Here is another take on what that thing could be. I don't have a good view to confirm it but it could be something like this:ringo wrote:That's a cooling hole. The radiator layout is not very efficient it seems.dren wrote:
The air speed at the bottom is to slow or too low a pressure, so the bust a hole through it and duct it to spupply more air from else where.
I wont be surpised to see cooling hoes by the splitter keel or behind the barge boards.
The chimney on top of the side pod near the turning vane is releaseing rejected heatfrom a KERS cooler, or it if we take out the KERS cooler and place the pipe behind the lower radiatior, it could be an extra side pod exhuast.
Either way it is a cooling solution.
