So.segedunum wrote:I'm sure they're having an intellectual discussion internally on Renault's interesting exhaust positioning but they're not going to panic into trying it because they'll just be wasting their time.
I think you can realize this obviously stems from your comments on other cars.segedunum wrote:Amusing to see some people have a go at Red Bull for changing the exhausts around on their car and their fit and finish.
This indirectly implies that the other teams are "shooting in the dark". Odd how depending on the team you have a very different reaction to nearly the same thing.segedunum wrote: It's not as if they're shooting in the dark here. ... It's not as if they're panicking trying to route exhausts in a completely different direction every three or four hours, like forwards, and then moving them to a more conventional position later to compare.
I'd imagine they aren't the only ones with intellectual discussions going on.segedunum wrote: I'm sure they're having an intellectual discussion internally on Renault's interesting exhaust positioning but they're not going to panic into trying it because they'll just be wasting their time.
SoliRossi wrote:Soem great back and forward in this thread. This car certainly generates lots of opinions and discussion.
Regarding the Renault engine, there was an earlier post that suggested it was smaller than the other engines, I was under the impression that the engine sizes were stipulated by the regs. Ie all the same size.
The renault apparently uses less fuel and has better cooling properties, but is down on power.
It would seem that RBR, i trying tos ecure a Merc donk for 2 consecutive years felt that it was better to have that power and sacrifice the other options. As was pointed out earlier, part of the reason the Renault is better on fuel is its reduction in power.
But they have got the whole package to win championships as is, but as if they would not have shelved Renault for Merc and the Merc KERS. That KERS is superb.
I don't know where people get this strange idea that it's 'all the same thing' when I've been at pains to point out exactly what the difference is. If you see a team coming to a test and putting components in at least three completely different places in the space of two or three days then you wonder what their initial idea was to start off with. If you see a team coming to a test with one idea and a component in one area, sticking with it and making adjustments then that's rather different, no? Whatever else you might think is pretty irrelevant, although I can see where you might be going with that red and Vodafone covered front wing as an avatar.volarchico wrote:This indirectly implies that the other teams are "shooting in the dark". Odd how depending on the team you have a very different reaction to nearly the same thing.
One team may have two or three ideas which the systems at the factory suggest might be beneficial in a similar way but which can't all be run on the car. They need to figure out which is the best idea in practice rather than theory.segedunum wrote:If you see a team coming to a test and putting components in at least three completely different places in the space of two or three days then you wonder what their initial idea was to start off with. If you see a team coming to a test with one idea and a component in one area, sticking with it and making adjustments then that's rather different, no?
Sounds good. You had the same doubts about McLaren's testing last year and even with their panic, flow-viz, and pitot-rakes, they managed to get 2nd place. We'll just have to see how it goes this year.segedunum wrote:Mind you, that's why the best are out in front and everyone else won't, or can't, think that way. Based on teams that have thought through ideas that they've brought to tests and stuck with them then I can see the top three teams as Red Bull, Renault and Ferrari, probably in that order.
We'll see what happens and then we can revisit this silly saga later and agree on who's been doing things right.
