beelsebob wrote:joseff wrote:beelsebob wrote:What do you think a flow sensor is? Hint - it doesn't directly measure the mass flow. It measures the pressure, temperature etc. The injectors are doing the exact same thing is the FIA's flow sensor is doing, they're measuring the exact same parameters, and doing the same maths to come up with a result.
Actually, it does measure the flow:
http://en.wikipedia.org/wiki/Ultrasonic_flow_meter
Read the very document you linked...
The device to measure fluid velocity, fluid direction, temperature.
The device to compute volumetric flow rate, cumulative volumetric flow, cumulative mass flow and mass flow rate. Mass flow can be determined from a calculated density‐temperature equation/lookup table
It does not directly measure flow. It measures velocity, direction and temperature. It then calculates flow rate.
it actually does measure flow, well, sort of, it uses doppler effect to get a value from the signal (ultrasonic wave) that the sender sent into the liquid and the receiver received (when the wave bounced off of an air bubble, even very tiny one), if there is no air or solids in the fluid - it cannot work
its reading will also be affected by any and all pressure weaves inside the fluid itself (and they for sure are there, the waves), by how much, no one probably knows for sure, but I bet there is no standard test to tell how accurate it would be for this very specific application, I bet those 0,25% and 0,1% accuracy numbers they specify in their data sheet, are for more or less steady/laminar flow
imagine it this way - if you hear the train coming your way (and you are standing very still) with its siren on - you can hear clear distinction when the train passes you - doppler effect, but if the train is also oscillating back and forth a tiny bit while still maintaining its average speed, then the sound you will hear will be distorted, by how much? it depends - factors - the frequency and amplitude of that tiny oscillation
no one will ever design a standard procedure for this type of accuracy test for such an instrument, just because it is way too application specific, and what smart people do in these cases - they use some other means of measurement, or come up with some special way of telling if the reading is reliable enough to be trusted - and those means in this case are - mathematical model of other parameters of the engine - pressure, temperature, injection cycles - which is what RB used to find out their actual flow rate and FIA chose to ignore (but still left themselves a loophole to dismiss that flow meter reading if THEY think it's wrong, using still the same techniques as RB did)
