Ferrari F2012
bhall
bhall
244
Re: Ferrari F2012
.poz wrote:Looking how it's shaped to me looks like more an exit for hot air than an entry
Agreed. For some reason I saw those slots as being reversed from the norm.
There's an inlet somewhere, though.
alogoc
alogoc
-10
Re: Ferrari F2012
in Bhallg2k i belive!!! god i hope you are right!!!
THE F2012!
THE CAR THAN WON 2012 WORLD F1 CHAMPIONSHIP WHIT A TILTED ENGINE!
bhall
bhall
244
Re: Ferrari F2012
Crucial_Xtreme wrote:Edit: what "holes" on the floor are you talking about?
On the outside of the diffuser. I've highlighted the one on the right with a faint yellow.
(Click to enlarge)
EDIT: Bigger picture.
MBilcke
Re: Ferrari F2012
@bhallg2k, can this be your entrance, on the line from red to black, above and behind your cheese-something?
Vanja #66 wrote:Image
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
EDIT: Zoomed-in picture.
The start of the convex shape of the diffuser. That has been there. Although what they're now doing with air there may have changed. See pic below from Bahrain.
shelly
shelly
136
Re: Ferrari F2012
It seems the two lateral black cheese graters could be the outlet for the central radiator (whose position is maybe different)
twitter: @armchair_aero
bhall
bhall
244
Re: Ferrari F2012
You're right, shelly. And they've been there. For some reason, they looked backwards to me when I first suggested that they could be an inlet for the double-blown diffuser.
zoro_f1
-2
Re: Ferrari F2012
Image “The force can have a strong influence on the weak-minded”: [Obi Wan Kenobi]
Re: Ferrari F2012
Crabbia
Crabbia
Re: Ferrari F2012
I know this mights be batshize crazy but what if the inlet you are looking for is inside the sidepods hidden from view. then there is a thin passage between the top and bottom of the floor between the hole you found to the sidepod. a kind of tunnel between the inside of the sidepod and the hole you found.
then the hole you found would have hot air from the sidepods flowing out of it pulled directly from the bottom of the sidepod using the ventury effect. as the air rushing past this hole will be moving very fast in comparison with the air in the tunnel, it would pull hot air out of the slower moving sidepod air.
A wise man once told me you cant polish a turd...
tpe
tpe
-4
Re: Ferrari F2012
amouzouris wrote:
tpe wrote:Is the back push-rod in the same position as (let's say) yesterday? To me it seems that is mounted much higher...
its not a pushrod...its a pullrod
Yes, it is... My hands are faster than my mind :)
But, the question is still valid. Is the rod mounted higher???
bhall
bhall
244
Re: Ferrari F2012
You mean like this?
amouzouris
105
Re: Ferrari F2012
Alonso is out on track again...lets wait for more photos...
Mesteño
Re: Ferrari F2012
Hi, I am new at the forum, im spanish.
I saw this photo and thaugt that maybe it is not only exhausting to the center, but to the brakes thanks to Coanda effect.
may I be right?
bhall
bhall
244
Re: Ferrari F2012
MBilcke wrote:@bhallg2k, can this be your entrance, on the line from red to black, above and behind your cheese-something?
I think that's a vent rather than an inlet.
But perhaps there's not an inlet.
(Click to enlarge)
The angle of the picture sucks, but the area I've highlighted in green could be curved forward in such a way that it collects everything passing over the floor and redirects it to the side of the diffuser.
Hopefully some better photos will emerge as the day wears on.
