Mr.S wrote:Can someone explain me the meaning of Aggressive???
Aggressive means taking chances. Ferrari is betting that the pull rod front suspension's potential aero/CG advantage, however slight, is worth risking reliability.
They're betting that getting air under the car is more important than having an aerodynamic nose, which is, in a way, placing a high premium on downforce even if it sacrifices top speed. In that arena, perhaps they've developed the first car that will absolutely rely on DRS.
From the looks of things, they're also gambling that their exhausts will aid flow to the rear, or produce downforce on the brake duct wings, without cooking the brakes.
It also appears that they're taking the chance that the exhaust housings will help direct air flow from the sidepods to the rear wing/beam wing, etc.
They've split the radiators into three locations to shrink the sidepods.
All of these things could work and produce a glorious car. Or, they could blow up, and render 2012 a useless year.
This Ferrari is all or nothing, and that's aggressive. At least that's how I see it.
