WOOOOW! This is HUGE! Cannot believe they penalized for this. What about all the other incidents... I can remember like 500 of them and they were IN the race not even qualifying.
I really think, this is not fair.
If lying to the media is an offence then Red Bull would have been thrown out of the last couple of years championships. They didn't lie to the stewards, they said they had honestly made as mistake in fuelling it.motobaleno wrote:I don't think so. macca LIED about the reason why they didn't return to parc ferme. that was the real problem.gibells wrote:It's a dangerous precident they've set. Any future failure to return to Parc Furme will surely require the same level of punishment, be it qualifying or race.
But the problem was he never ran out of fuel.myurr wrote:You can underfuel by 1 litre. As that would have given Lewis enough fuel to return to the pits, that is what he's been accused of gaining an advantage from.Nando wrote:Only first one works.
If you can get back to pits you haven´t underfueled the car.
Not when they quote chapter and verse for the reason he was disqualified, i.e. article 6.6.2motobaleno wrote:I don't think so. macca LIED about the reason why they didn't return to parc ferme. that was the real problem.gibells wrote:It's a dangerous precident they've set. Any future failure to return to Parc Furme will surely require the same level of punishment, be it qualifying or race.
Exactly. Just run wide.astracrazy wrote:nail on the headbeelsebob wrote:So conclusion... There's at least 3 ways around this rule:
1) Underfuel, do your lap, dump it in the gravel.
2) Underfuel, do your lap, come back in, put plenty of fuel in the car for a second run, go out, do another lap, return to parc-ferme.
3) Underfuel, do your lap, come back in, decide not to go out on track again.
not crash, just "run wide" and get stuckPierce89 wrote: no, if Lewis crashed he wouldn't be on pole. Tbey would hae to work on car under Parc Ferme conditions.
But the hypothetical situation we've postulated is deliberately doing a run without enough fuel for the sample, putting more fuel in and then doing another aborted run with enough fuel. Thus getting around the rules.Nando wrote:But the problem was he never ran out of fuel.myurr wrote:You can underfuel by 1 litre. As that would have given Lewis enough fuel to return to the pits, that is what he's been accused of gaining an advantage from.Nando wrote:Only first one works.
And he did have enough fuel for the FIA.
He got disqualified for not returning to the pits.
No this is wrong.beelsebob wrote:You can underfuel by 1 litre by doing 2 or 3 (you don't have to provide the sample to the FIA because you return to your garage, not to parc ferme).Nando wrote:Only first one works.
Yep – once again – I don't think anyone is disputing that Hamilton broke the rules and should be penalised, only that the rule seems to be unenforceable in a number of circumstances, and hence rather a mad rule to have.Nando wrote:But the problem was he never ran out of fuel.myurr wrote:You can underfuel by 1 litre. As that would have given Lewis enough fuel to return to the pits, that is what he's been accused of gaining an advantage from.Nando wrote:Only first one works.
they never lied, they only said they had a technical issue....myurr wrote:If lying to the media is an offence then Red Bull would have been thrown out of the last couple of years championships. They didn't lie to the stewards, they said they had honestly made as mistake in fuelling it.motobaleno wrote:I don't think so. macca LIED about the reason why they didn't return to parc ferme. that was the real problem.gibells wrote:It's a dangerous precident they've set. Any future failure to return to Parc Furme will surely require the same level of punishment, be it qualifying or race.
but that's ok, just miss the scrutineering/weight bridge like torro rosso did last raceCrucial_Xtreme wrote:No this is wrong.beelsebob wrote:You can underfuel by 1 litre by doing 2 or 3 (you don't have to provide the sample to the FIA because you return to your garage, not to parc ferme).Nando wrote:Only first one works.
6.6.2 Competitors must ensure that a one litre sample of fuel may be taken from the car at any time during the Event.
Except in cases of force majeure (accepted as such by the stewards of the meeting), if a sample of fuel is required after a practice session the car concerned must have first been driven back to the pits under its own power.
Sure, but the practice of it is that the FIA don't take fuel samples between runs in Q3 because there simply isn't time to do so, as a result, you get a chance to get back to the pits, put some more fuel in, and mask the fact that you were ever low on fuel. Again – the argument is that the rule is not enforcable, not that it's not illegal.Crucial_Xtreme wrote:No this is wrong.beelsebob wrote:You can underfuel by 1 litre by doing 2 or 3 (you don't have to provide the sample to the FIA because you return to your garage, not to parc ferme).Nando wrote:Only first one works.
And how often do they provide that sample. The point is that unless they're actively taking fuel samples throughout Q3 then they wouldn't be detected.Crucial_Xtreme wrote:No this is wrong.beelsebob wrote:You can underfuel by 1 litre by doing 2 or 3 (you don't have to provide the sample to the FIA because you return to your garage, not to parc ferme).Nando wrote:Only first one works.
