Red Bull RB9 Renault
imightbewrong
imightbewrong
Re: Red Bull RB9 Renault
gandharva wrote:Very Interesting. RBR now uses the swan-neck air-inlet to feed both, beamwing and rearwing DRD. We already speculated about the extension of the system to the rearwing.
/edit 1
imightbewrong wrote:See this picture to see that it is a hole all the way through the beam wing:
http://oi49.tinypic.com/2l9k2nr.jpg
It isn't. Just search for pics where you can see the beam wing from the other side. No hole in any of the pictures. What you are referring to is reflections from the metal plate they mounted on both sides of the beam wing. It's there since first Barcelona test.
/edit 2
Here you can see the metal plates in the beamwing without any hole:
http://www.motorsport-magazin.com/image ... 472570.jpg
Maybe those metal plates contain the beamwing DRD trigger...
I disagree, I think that picture shows the channels. You can actually see the hole between the endplate and the metal plate on the beam wing and see the tarmac through it:
imightbewrong
imightbewrong
Rikhart wrote:
imightbewrong wrote: Alright, I see. So the assumption is then that since there is flow viz there they are trying to monitor something there, and that must be the DRD?
Thats how I interpret it, at least!
Ok, we'll have to disagree on that point then. My theory is that they are checking the flow (of among other things on the beam wing) the tiny double element part that they are running next to the endplate, and that is why they have flow viz there.
gary123
I'm curious to know from where comes the air that feeds the drd :?:
dren
227
gary123 wrote:I'm curious to know from where comes the air that feeds the drd :?:
I'm guessing the way the inlets split under the exhaust ramp, one of them feeds it. Either that or it pulls air from the engine intake or the sidepods.
Honda!
gary123
yes it could be
zoro_f1
-2
new parts just arrived in red bull and new chassis as well.
Image “The force can have a strong influence on the weak-minded”: [Obi Wan Kenobi]
raymondu999
Interesting. I wonder what this will hold. Mind you I don't expect anything as last year's RB8-B
失败者找理由,成功者找方法
Barcelona (Test 3, Session 2) - Day 2 (01.03.2013)
Forza
238
Close-up of DRD
The channel feeding the DRD is longer than I thought
McG
-19
Finally, everyone knows that Red Bull is a joke and Max Verstappen is overrated.
Was it disallowed?
Forza
238
F1 test - BCN T02 - Day 2
dxpetrov
dxpetrov
-7
This car is just a feast for eyes! =D>
