cool man!scarbs wrote:
You should check gurneyflapringo wrote:
cool man!
Interesting, first time i'm getting this kind of shot.
Thank you!RacingManiac wrote:Trying my best here with the pics...
I googled the picture, which was quicker than going through my archive of photos. Its a 2002 Renault and pretty typical of a front ARB installation, aside from Ferrari and the Brunner designed Minardis, that use a ingenious blade type ARB. Its lacking a heave damper, you can see the links on the rockers where it would fit.Belatti wrote:Thanks Scarbs, nice pic!
Do you know wich car is it? Does it has an horizontal 3rd shock/spring? Are the pedals missing there?
Perhaps. However, it would be a surprise if there isn't a bump rubber in the stack.speedsense wrote:The top one, closest to the t-bar, appears to be a helper spring. Helper springs keep the sprung unit from rattling loose during extension, and are quite light in spring rate by comparison. This is likely a dual sprung unit, not a triple. IMHO
Mmm. I think you have it, auto. "Aerostatics" rules OK. Does work for LMP, GP2 & (some) F1 teams, however.autogyro wrote:I dont think that would work to keep the ride height acceptable with the DF changes with speed Dave.
As usual aero rules OK.
why not throw away the steel spring altogether and just have a bump rubber with zero gap but a very low initial rate and progression ? got 800g of weight removed from the car instantly..DaveW wrote:Perhaps. However, it would be a surprise if there isn't a bump rubber in the stack.speedsense wrote:The top one, closest to the t-bar, appears to be a helper spring. Helper springs keep the sprung unit from rattling loose during extension, and are quite light in spring rate by comparison. This is likely a dual sprung unit, not a triple. IMHO
The issue (for me) is that the rate change(s) will happen suddenly (apart from the bump rubber). Sudden changes in rate wouldn't inspire driver confidence if they happened during a manoeuvre. No doubt, and with no road inputs, that could be avoided by careful "tuning", as RH suggested. In reality, however? Unlikely, I think.
Why not marry a single spring with a long(er) bump rubber, "tuned" with packers? Removes any requirement for a "helper", would probably reduce weight and would make rate changes smoothly progressive....
Curiously, I've seen that solution. It's a question of load capacity, I guess, & the proportion of the load carried by the corner springs. For example, it probably wouldn't work with no corner springs (I've seen that solution, too).marcush. wrote:why not throw away the steel spring altogether and just have a bump rubber with zero gap but a very low initial rate and progression ? got 800g of weight removed from the car instantly..
Something like that has been used previously - a stack of, effectively, dished washers used as a very stiff bump stop that also worked as a third spring. Not as ultimately compliant as a coil spring though.marcush. wrote: why not throw away the steel spring altogether and just have a bump rubber with zero gap but a very low initial rate and progression ? got 800g of weight removed from the car instantly..
