McLaren MP4-29 Mercedes
daveyrace
daveyrace
Re: McLaren MP4-29 Mercedes
Blackout wrote:
daveyrace wrote:They look almost like paddles, the lower one is definitely a different shape to the upper.
http://i.imgur.com/lHkSePi.jpg
So they made two superposed 'Blonchimont bells'' out of the upper wishbones ?
Using 'Blanchimonts bell' shape I think the rear suspension is laid out a bit like this simple diagram. With the rear parts being able to be bolted on or off the wishbone(shown in a picture above by gandharva) and being asymmetrical(longer section between the arms, how that would work with the rules is beyond me.
I don't think they open up or move(in relation to the suspension arm), I think they create downforce onto the rear suspension and produce a low pressure zone behind which the air from the diffuser is 'attracted' to, not the right terms I know but I am in an armchair.
f1rules wrote:looking at this Picture maybe they are meassuring devices
http://www.formula1.com/wi/enlarge/0x0/ ... 9ja038.jpg
With brightness and contrast enhanced...
Don't know what to make out of it, honestly...
Coefficient
Coefficient
Just noticed there is no visible weave in the material used for the rear floor. Surely they wouldn't waste time/weight painting the floor? I know it isn't but it looks like bakelite. LOL!
Coefficient
Coefficient
http://i1364.photobucket.com/albums/r72 ... b0ca89.jpg
Well it ain't pretty but if it brings performance I'm all for it.
acosmichippo
acosmichippo
this pic makes their cross section look almost square, with rounded corners. not bell shaped.
SectorOne
Never seen anything quite like that,
CBeck113
CBeck113
51
They're bolted on too - I cannot see that being a permanent piece of the suspension arm. If they are sensors, then for what? Temperature or stress? They have a big influemce on teh aero, so I think that can be ruled out... :?:
Rikhart
Rikhart
I´m almost sure those are some sensors wrapped around the suspension arms, maybe for vibration, or something like that... You can see the taped wiring so characteristic of sensors, on the crash structure.
These are the suspension arms placed vertically instead of horizontally. What they try to achieve is a mystery though.
Rikhart
Rikhart
turbof1 wrote:These are the suspension arms placed vertically instead of horizontally. What they try to achieve is a mystery though.
No, its not, its something wrapped around the arms. Suspension arms are not thick squarish things held together with bolts...
Shakeman
Rikhart wrote:I´m almost sure those are some sensors wrapped around the suspension arms, maybe for vibration, or something like that... You can see the taped wiring so characteristic of sensors, on the crash structure.
I'm going with sensors too.
Mr.G
34
Looks like some kind of measuring device for me.
acosmichippo
acosmichippo
maybe a shroud to conceal what the actual shape is?
f1rules
f1rules
621
for sure for meassure, can even see the wiring
Scarbs mentioned they are placed vertically. I came to the same conclusion because of the general shape.. They do look bulbuous, but better pictures are needed to say anything conclusive.
