I'm pretty sure that this is not the complete passive DRD setup... and is just a mock up to see how it will affect other systems.Rikhart wrote:It looks like a much cleaner and unobstructive design like that. Much better for the flow over the beam wing certainly. But I wonder why is it off-kilter? Its not properly aligned with the center of the wing
The lower pipe is covered and the "diffuser" part is built into the engine coverkorzeniow wrote:Yay! I'm also suprised.
But this looks to me rather like "quick" test solution. The pipe isn't connected to the rear wing's main plate and outlet tube is missing together with special monkey seat.
I think this is temporary test solotion that you can quickly put on and quickly remove.
The one posted by me it is the E21 and the other two posted after that are of the E20 with the version of the DRD tested last year.ak21_rao wrote:These pics don't look like they are of E21....
