If its stays like this we will see a Medium Wet tires used by most teams while some might start with FULL Wet hoping they gain a bit of an edge as the rain continues to fall or and immediate edge..myurr wrote:I think that looks just about perfect for a good wet race. It'll be damp but not dangerous as the race starts, with constant light rain progressively getting stronger towards the end of the race. I know it's likely to change, but if that's how it pans out then I think we could be in for a thriller.beelsebob wrote:yr.no still sayeth:Gerhard Berger wrote:Forecasts are changing, we may not even have a wet race tomorrow.
However if I remember correctly both tires have a certain temperature in which they need to be kept or they deteriorate so making a bad choice could mean you make yore self and easy target for overtaking.. And depending on the set ups some cars might work better on either tires this is going to make everything have a certain degree of luck..
