Ferrari F2012
Gerhard Berger
Gerhard Berger
-1
Re: Ferrari F2012
FrukostScones wrote:the front pull-rod suspension might be mechanically sound but it's unnecessary (Adrian Newey said so, only reason to do it is to do it differently) and aero realted it was clearly a mistake (unwanted, hard to evaluate vortices disturbing airflow),
that is what I read and it made sense to me.
I bet it will be gone 2013.
Tombazis said it has an aerodynamic benefit.
I know that alot of papers have said there that it creates vortices which were not seen in the wind tunnel. Not sure how true that is though.
amouzouris
105
Re: Ferrari F2012
I'm sorry for the delay...i was too busy with exams...but i managed to make drawings of most of the upgrades brought in Spain... i didn't manage to finish the slight variations of the bodywork around the exhaust area...ill try to finish it before Monaco!
First up is the new front wing:
There were slight modifications to the endplates to make them work more efficiently...also there were new cascade wings... the innermost part now features two elements and the outermost part is shorter where it meets the endplate:
Also a new diffuser was tested in Spain and the monkey seat was added on the new detached beam wing tested in mugello...
Old diffuser:
New diffuser and beam wing featuring the monkey seat and a gurney flap on the beam wing, also the wing shaped flap on top of the diffuser now also features a gurney flap....the diffuser strakes have been reshaped and are more curved at the bottom now and there are dips where the two big strakes meet the top of the diffuser (ala Red Bull)...the wing shaped flaped has also been reshaped on those two areas:
Redragon
19
Re: Ferrari F2012
xpensive wrote:
Redragon wrote: ...
Get over it, not reasons to blame that suspension.
You know what, when this is a discussion board, I will reserve myself the right to an opinion even if it contradicts even the wisest and most xperienced of engineers on this fine forum.
Based on earlier arguments, I still believe that Ferrari went too far with this layout, but that it will be the way to go in 2014.
You have absolutely right to have an opinion, not trying to changed it. But we know your point of view already, I don't think it is necessary to remind us until 2014.
Ferrari has decided to go for Pull-rod in front, so less drop this discussion and move on.
xpensive
xpensive
214
Re: Ferrari F2012
Redragon wrote: ...
That is by no means your call and I believe that you should seriously consider your menbership if you think otherwise.
Besides, there are obviously other members than myself who consider said topic still interesting.
Teechnical
Re: Ferrari F2012
Would the new rear diffuser and beam wing shape affect the car enough to give it a tenth or two?
"We have a new toy" - Fernando Alonso.
amouzouris
105
Re: Ferrari F2012
Teechnical wrote:Would the new rear diffuser and beam wing shape affect the car enough to give it a tenth or two?
is suppose it would give at least a tenth...as the central part is now detached and sits in 'clean' air now it can make much more downforce...with this you can also reduce a bit the AoA of the RW and gain a bit of top speed!
Redragon
19
Re: Ferrari F2012
xpensive wrote:
Redragon wrote: ...
Ok let's carry on, brining every single time the pull-rod front suspension topic. I am considering my menbership just because it is too predictable this forum and boring. What ever happens in Monaco, good result or not from Ferrari this would be your argument, if good result, it could have been better if they would have used push-rod. If it is bad result, I told you it is because of Pull-rod and bla, bla, bla...
I also have an opinion. I don't think it is necessary that you remind us the Pull-rod topic, we know. We have move on and be interested on other developments and parts that Ferrari are brining on. I am not an engenier but if I was it is as much interesting how they are developing a car that it is different than the rest on that area, working or not.
myurr
myurr
Re: Ferrari F2012
Well said. If it wasn't working then they would have replaced it.
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Good drawings Z. It should also be noted the actual shape of the beam wing has been changed too. It's now more "twisty" whereas the old one was flat & straight.
I still cannot find ANY clear up close pictures of the new rear brake duct fins. From what I can see the top of the fins are similar to Red Bull and at the front the duct is low and there's the one element that is at an angle where it looks like it's deflecting/directing air flow downwards. I just wish I could get some good up close detailed shots. :evil:
Obviously the car still has work to do, needs more updates but I think sector 3 in Montmelo showed we've have improved significantly the low speed traction & grip issues. We were amongst the fastest all weekend. Even on low fuel. Hopefully new updates will improve this even further.
Gary Anderson is still on about the vertical radiators and/or about how the flow from them exits. I'm curious to see if we will change the radiator layout or if we will change the outlet to a more conventional style. Possibly with the new Engine cover we saw in Malaysia although it would be modified now.
I also don't think Ferrari need to pursue DDRS. I think it's a waste of time and would take away from more fruitful development. I don't think it gives a large enough advantage. I do expect to possibly see a revised exhaust possibly. But maybe not as Fernando said they shouldn't waste time on it, there are more important things. I think he's probably echoing the sentiment of the development team.
X those pull-rods were working great in Spain. :p I was proud. :D
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Any ideas on what the heck this is?
elFranZ
Re: Ferrari F2012
Crucial_Xtreme wrote:Any ideas on what the heck this is?
https://p.twimg.com/AtLo6ZnCAAM_FSZ.jpg
LOL, I'm struggling too :D
Nando
Nando
Re: Ferrari F2012
xpensive wrote:
Redragon wrote: ...
...and that´s your call?
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Nando wrote:
xpensive wrote:
Redragon wrote: ...
Let's not litter this thread with garbage mate. X is entitled to his opinion and is free to discuss it. I don't agree with him and I think he's dead wrong about the pull rod front suspension. But he has every right to post that he thinks it's a problem. It's no big deal, we all have our opinions.
Now everyone can we get back to the car and away from dead horses? :)
beelsebob
beelsebob
85
Re: Ferrari F2012
Nando wrote:
xpensive wrote:
Redragon wrote: ...
The point being that it's fair enough to say "I'm not interested" and walk away, but it's not fine to say "I'm not interested, you can't have this discussion any more."
Postmoe
Re: Ferrari F2012
Nando wrote:
xpensive wrote:
Redragon wrote: ...
Yes, because as it happens with front pull-rods, Redragon membership simply doesn't look well. Just imagine how it would be if he had a more conventional push-rod membership...
Ok, I'm stopping, but please... this is so absurd. I'm imagining people praying for a massive suspension failure after the tunnel... we shouldn't be so personally related to our own opinions. We need to take ourselves less seriously.
