Holm86
249
This valve getting stuck could explain the brake failure for Max in Melbourne, overheating only the right side brake disc
Vaexa
Vaexa
u/GaryGiesel (who, you know, actually works in the sport, unlike Windsor, Scarbs or the guy who wrote the RN365 article) seems convinced the system peddled by the article and Scarbs wouldn't even work.
https://www.reddit.com/r/F1Technical/co ... s/lidrnd8/
Even if this thing were real, the system Scarbs has shown literally wouldn’t work. The pressure everywhere in the rear hydraulic circuit will equalise so the valve doesn’t do anything unless it’s fully blocking off one side of the brakes (which it won’t be because you’d end up doubling the caliper pressure on the inside wheel or locking the pressure on in the outside one… not at all doing what you’d want)
We're all collectively falling for fanfiction sprinkled with some technical jargon because it fits some circumstantial evidence. Very disappointing.
Holm86
249
Vaexa wrote:
16 Aug 2024, 15:43
These cars have variable brake pressure on the rear wheels due to variable ERS harvesting, so I'm pretty sure the "doubling of caliper pressure" could be worked around if that was the case
Tiny73
Tiny73
Isn’t Occam’s razor more relevant in his denial of this? He’s not going to say “yeah, you caught us, that’s what we were doing and got busted” is he?
Vaexa
Vaexa
Tiny73 wrote:
16 Aug 2024, 16:19
I find it far more likely he just wouldn't have said anything at all if Red Bull were actually doing anything like what the RN365 article proposed.
Curbstone
Curbstone
Holm86 wrote:
16 Aug 2024, 16:06
Vaexa wrote:
16 Aug 2024, 15:43
If you can achieve uneven braking through the ERS-system without being caught, why would you go through the trouble of trying to achieve the same thing with the traditional brake system?
I always thought highly of Scarbs, but I reckon GaryGiesel is right and Scarbs really misses some basic fluid mechanics in his design.
yooogurt
40
Quantum wrote:
16 Aug 2024, 12:47
16 Aug 2024, 12:29
He's a mechanic in the garage every weekend
Not sure I was clear.
Yes, he's a mechanic in the garage every weekend. We established this fact by way of the citations I provided.
Specifically, prepping the PU and checking it's fluids.
Not responsible for the brakes or any lines associated to the brake function. This would be a role for someone else. Maybe that's clearer.
Have you ever seen a current employee admit that a team is using a gray zone of regulation?
It's obvious he would deny it, whether that theory is true or not.
FORZA FERRARI!
Holm86
249
Curbstone wrote:
16 Aug 2024, 16:47
Holm86 wrote:
16 Aug 2024, 16:06
Vaexa wrote:
16 Aug 2024, 15:43
Read it again, never said you could use the ERS system to achieve uneven braking left to right, i said the brake system already have valve reducing brake pressure to the rear when the ERS is harvesting, it could be used to not have double brake pressure on ONE caliper, but you would still need some sort of diverter valve left to right as scarbs is suggesting. And nobody is saying that scarbs drawing is 100% correct, it's only a suggestion
basti313
basti313
Holm86 wrote:
16 Aug 2024, 15:41
No. The idea of a valve is just completely wrong. This would need an adjustable pressure regulator and bleeding system which is very obvious and blatant cheating as by the rules since years. You are on the wrong track with this, sorry.
Brake pad force left to right NEEDS to be the same by the rules since many years.
The new rule clarification only goes into ERS and engine braking. It simply has nothing to do with hydraulics.
Curbstone wrote:
16 Aug 2024, 16:47
I am surprised, but most posters here on this brake topic do not even know about the brake-by-wire system or how it works.
Funny thing with the new rule: In principle a differential always gives asymmetric engine braking depending on the steering angle...so I have a feeling they really had issues with even finding that wording. :mrgreen:
The most clear indication for me is the downshift issues. It was always ridiculous, slapstick how RedBull was struggling with shifting gears while the AT/RB was somehow able to operate the same engine and gearbox. In hindsight that nicely fits the tracks where they were struggling with braking or getting the car round a corner. So for me this is the smoking gun...
Curbstone wrote:
16 Aug 2024, 16:47
Yep. The idea of the valve is technically nonsense and nonsense by the rules as it is clearly against the rule about the brake pad force and the "mass damper rule" that forbids any inertia driven system.
Holm86 wrote:
16 Aug 2024, 17:51
... i said the brake system already have valve reducing brake pressure to the rear when the ERS is harvesting, ...
There is no valve. It is always brake master cylinder to caliper, nothing else. An F1 car has three master cylinders, one front to calipers, one rear to BBW and one in the BBW system to calipers.
Don`t russel the hamster!
Jurgen von Diaz
-1
Curbstone wrote:
Jurgen von Diaz wrote:
15 Aug 2024, 14:25
Curbstone wrote:
You design the car for a full year, not just half a year. Let's have a look at the points tally and number of wins at the end of the year before we state Red Bull did a great job with it's car design.
I have some strong doubts. Looking at the steps others have made it doesn't seem they are close to the performance ceiling, so I don't believe RB should be either.
Yes, you design the car for the full year. They have chosen their aim for the WDC, and if Max will be champion, how can we doubt their design path? They clearly haven't got such dominant tools like the hybrid-Mercedes that they can run their cars underpowered, so Red Bull has chosen this design path so Max can push it to the limit and towards the championship. If they had chosen a different design path, could they even fight either championship and Perez would be happier? We'll never know.
How do you know they have chosen to aim for WDC? At the end of last year they were convinced the could sort out the weaknesses of 2023, last years they already put a lot of effort to give the car a wider set-up window in order to have Perez be more comfortable with the car, and for this year they changed some concepts in order to bring more room for development. This doesn't sound like a team that will design a car just for Max. Also, Max has been complaining a lot about not having a strong front-end and having difficulties to rotate the car.
I don't believe it's a design path that suits Max. I think the car has some serious flaws which makes it hard to setup and which requires an exceptional driver to drive around the issues.
With Pérez, the WCC would be a difficult main goal; he is just that bad. The WDC is a more natural main goal for them. I mean, if Max wins the championship, how much can we criticize Red Bull about their design path? Not every team is perfect, but come on, let's look at this from another perspective; the Red Bull driver is leading the championship by 78 points, and we are talking about what Red Bull should have done differently.
catent wrote:
16 Aug 2024, 20:49
16 Aug 2024, 15:17
Quantum wrote:
16 Aug 2024, 12:47
Not sure if you were trying to be condescending, but it's not helpful to constructive discussion and not appreciated.
My point is that he doesn't work on the power unit in a vacuum. Your suggestion that because he works on the PU he would therefore necessarily not know anything about the braking system of the rb20 is ridiculous
On the topic of condescending, unhelpful, unconstructive posts, what do you think about calling someone else’s opinion “ridiculous”?
If someone is a mechanic who has worked at the team in many roles over the years, who speaks to their colleagues daily, helps to build/take apart the car every weekend. In my view it is plainly absurd, silly, ridiculous to assume they cannot know anything about the brake system and their view should therefore be discounted because their current primary role is working with the PU. I don't see how that's unhelpful, condescending etc. just my view on someone else's point being incorrect.
Aside:
Calum Nicholas is not the only rbr employee that works on the rb20 that has said publicly they've never heard of such a system being on the car. But hey, maybe it's all a coordinated response :?
emp
emp
RacePaceDemon wrote:
17 Aug 2024, 03:32
catent wrote:
16 Aug 2024, 20:49
16 Aug 2024, 15:17
<personal stuff removed>
Also, it is ridiculous to even think that mechanics work in a vacuum on a car in a race weeekend. Just because it's not their job at the moment doesn't mean they are clueless, otherwise a lot of the armchair experts would've worked in F1.
What if one is sick, or more are sick in a weekend, the team will just not compete because no one else can do their job ? Ridiculous indeed.
Quantum
I provided Red Bulls head mechanic Phil Turner's account for how the car is assembled.
An F1 car is not an off the shelf one size fits all jack of all trades mechanic can simply assemble. Turner goes into that.
Each mechanic has their specific role.
Turner describes it as "bespoke".
What that means is specifically tailored to that individual part of the car.
He even outlines it. "We build it in pieces"
Front end mechanic does front end, number 1 mechanic does fuel lines, PU guys do install. BESPOKE.
Turner also says he will get his hands dirty
"If the need arises". Ie sickness.
Being head mechanic it is absolutely essential for him to know everything. If he came out and said BS, then there's validity to "ridiculous" attacks had he been the source of the denial.
There is no source to validate Calum being able to assemble the brake system.
That is pure speculation. It's not his job.
I can speculate too.
It's also bereft of logic to tell the entire assembly team what a hypothetical magic bullet device does unless they need to know.
Why on earth would a team develop (supposedly) magic bullet brake system and then tell the PU install guy all about it?
F1 is about IP retention. It goes without saying teams implement strict controls on who knows what.
My opinion is Calum genuinely doesn't know even if there was a system being deployed by RB. Because he wouldn't be in that information loop.
"Interplay of triads"
chrisc90
Well if people are quickly dis-regarding Calum's input into the brake valve, then we can dis-regard some media journalists take on the system even quicker because they are even further out of the potential information loop than a member of the team. Especially when such system isn't plausible anyhow.
