The point being that they couldn't keep it open at the 250km/h that they enter that corner at, so it needs to be tuned above 250km/h.turbof1 wrote:They didn't entered Pouhon with DRS, but right after getting on the power mid corner, they opened it up.
Even at the 160km/h that the left hander after rivage is taken at, you're still paying a significant drag penalty.Both Rivage and Fanges are slower corners. The drag penalty of the rear wing isn't an issue there, so why even bother stalling the rear wing even if it was possible (certainly is not).
This will still make you slower down the straights, as you will be slower right up to the point where you hit max speed due to the increased rear wing drag.However, if you tune the DRD so that you run more rear wing for the same top speed as without DRD
Indeed, so you might make up some of the time you still lost on the straight (possibly all of it, but probably not by a considerable margin).you have more downforce thus more speed in les combes, rivage, fanges, stavelot and perhaps even the bus stop chicane.
Again, if you do this then you lose time all the way down the straight, the acceleration curve flattens out, and then hits it peak more sharply.DRD really should be set up for more downforce in these corners instead of more top speed for the same downforce.
Yes, yes I did, because almost every single corner at Spa is high speed and needs the downforce still workingBtw, you just name almost every single corner except the slowest ones on Spa.
Again, this does not matter. The key is not "how many corners can I drive through with DRS open", but "at what speed am I able to calibrate the DRD to open". The two are fundamentally different – one can be opened by the driver at will, the other can only be opened at a certain speed. For the latter to work well, that speed needs to be a low speed, at spa, it can not be a low speed.There is not a single circuit last year on which teams drove through with DRS so much of the circuit. If that was possible in the first place, teams wouldn't bother mounting a rear wing.
