that's some skinny, tight area at the gearbox section
and that nose is interesting. That's quite the refined car imho, didn't expect so 'much' change
Even more changes than Aston you reckon?... I mean, they have a complete new rear end inherited from Mercedes, and completely different sidepods/monocouqe middle section aswell....
that's a really good looking car from this angle. interesting angle aswell!
Apparently they didn't change the crash structure inside the nose (that is the part that is homologated and tokens must be used to change it) but just changed the bits on the outside.
Visibly I think so. They’ve seemed to have touched almost every section on the SF21’s bodywork and it also is sporting a new rear suspension. The Aston at least kept the same nose design.HungarianRacer wrote: ↑10 Mar 2021, 15:52Even more changes than Aston you reckon?... I mean, they have a complere new rear end inherited from Mercedes, and completely different sidepods/monocouqe middle section aswell....
The end is defined by rules, so they must to comply...mantaque wrote: ↑10 Mar 2021, 16:05Interesting detail: looks like exhaust wastegate pipe has a change in diameter:
https://i.imgur.com/l0VEThU.png
Like with everything, but I just wonder what advantage you gain with this design.Mr.G wrote: ↑10 Mar 2021, 16:07The end is defined by rules, so they must to comply...mantaque wrote: ↑10 Mar 2021, 16:05Interesting detail: looks like exhaust wastegate pipe has a change in diameter:
They can have thinner pipe = less weight, then the rules define it must be wider for the last few cm, so they changed the diameter back...mantaque wrote: ↑10 Mar 2021, 16:11Like with everything, but I just wonder what advantage you gain with this design.Mr.G wrote: ↑10 Mar 2021, 16:07The end is defined by rules, so they must to comply...mantaque wrote: ↑10 Mar 2021, 16:05Interesting detail: looks like exhaust wastegate pipe has a change in diameter:
