In purple the edges of engine cover and sidepods.
In yellow something interesting at exhaust level.. can't define it but it seems to have two different radius...
Twisted beam wing? AT03s is parabolic.Giando wrote: ↑15 Feb 2022, 15:08https://postimg.cc/fkzSVywS
In yellow something interesting at exhaust level.. can't define it but it seems to have two different raidus...
It looks as though it has the track-rod running through it?
Blackout wrote: ↑15 Feb 2022, 15:38AT beam wing is standard showcar beam wing
https://i1.wp.com/f1-gate.com/media/img ... c42-04.jpg
https://cdn-9.motorsport.com/images/mgl ... -c42-1.jpg
This, with none visible rear air exits or gills over the sidepod...AeroDynamic wrote: ↑15 Feb 2022, 14:25https://i.imgur.com/WJc6AJ0.jpg
https://i.imgur.com/mVOecPC.jpg
And some grillsAeroDynamic wrote: ↑15 Feb 2022, 15:41https://i.imgur.com/vGZRkJn.jpgBlackout wrote: ↑15 Feb 2022, 15:38AT beam wing is standard showcar beam wing
Nice catchJolle wrote: ↑15 Feb 2022, 15:53And some grillsAeroDynamic wrote: ↑15 Feb 2022, 15:41https://i.imgur.com/vGZRkJn.jpgBlackout wrote: ↑15 Feb 2022, 15:38AT beam wing is standard showcar beam wing
Yeah, those posts were removed by a mod that knows aero, if I remember correctly. There'd be a reason for that.SiLo wrote: ↑15 Feb 2022, 14:26Saw someone say the diffuser is single kick. I think Godlameroso was talking about this in the 2022 comparison thread where a second "kick" is designed into the floor to help stop the flow at the throat of the diffuser from becoming sonic.
Hopefully he can come and explain it more detail.
I think there is a track/steering rod clear right in front of it, but behind that, it looks beefy. A “Merc 2014” solution would make sense if you want to clear that area, especially with a push rod. You will have a whole flow from under the nose, going straight into the floor
Thanks! This night I will can sleep.Jolle wrote: ↑15 Feb 2022, 15:53And some grillsAeroDynamic wrote: ↑15 Feb 2022, 15:41https://i.imgur.com/vGZRkJn.jpgBlackout wrote: ↑15 Feb 2022, 15:38AT beam wing is standard showcar beam wing
Their tunnels behind the entries seem to be very low, so low that the crash structure is protruding (the bump)
good catch. Looks like they're up against the whole of the flat portion of the floor
