Ciro - The Autocoast Ti22 had some success and the designer went on to design the controversial Shadow CANAM cars with sucess. I'm learning things I didn't know.
"The 1969 Ti22 Mk 1 was the first American built car to lead a CANAM Race in 1970. Along with the 1970 Ti22 Mk2 they scored more points in the 1970 CANAM Series than any other American designed cars. Peter Bryant is also a pioneer in the use of Aerodynamic ground effects to enhance cornering. The chassis was largely titanium sheet and bulkheads with a patented attachment system. Suspension castings and links were primarily titanium.
In 1971/2, Peter Bryant designed the UOP Shadow Can-Am cars driven by Jackie Oliver and Carlos Pace in the Can-Am races.The Shadow Mk2 (1971) and the Shadow Mk3 (1972) . These 2 cars were the leading American designed sports to run in the Series in those years. Bryant designed cars scored more points in the CANAM than any other American designed cars including the legendary Chapparals. From 1966 to 1971 Chapparal scored 79 total points and in a shorter period from 1969 to 1972 Bryant designed cars scored 94 points total. The UOP Shadow cars were the first road racing cars to run on Unleaded gasoline and in 1971 Bryant was invited to give a paper about this to the SAE Millwaukee section. As a result he was invited to become a member of SAE and was subsequently made a member in 1973.
Following his retirement from professional racing in 1973, Peter Bryant wrote the first definitive Paper on racing car Aerodynamic Ground Effects and presented it to the AIAA at their second symposium on Automobile Aerodynamics in Los Angeles. (1973 “The CANAM Car and Ground Effects”)" Compiled from memory and several internet sources.
Ciro - It will not surprise you that you were correct about the engine configuration of the Porsche 917-30
Engine 912.52 180º V 12
Engine Location Mid , longitudinally mounted
Configuration magnesium alloy block, aluminum alloy head
Displacement 5.374 liter / 327.9 cu in
Bore / Stroke 90.0 mm (3.5 in) / 70.4 mm (2.8 in)
Compression ratio 6.5:1
Valvetrain 2 valves / cylinder, DOHC
Fuel feed Bosch Fuel injection
Aspiration Twin Eberspacher turbos
Performance figures
Power 1100 bhp / 821 KW @ 7800 rpm *1500HP qualifying engine
Torque 1112 Nm / 820 ft lbs @ 6400 rpm
BHP/Liter 205 bhp / liter
Power to weight ratio 1.3 bhp / kg
Top Speed 386 km/h / 240 mph
0-60 mph Acceleration 2.1 s
0-100 mph Acceleration 3.9 s
Note: The Porsche 917 endurance prototypes were all flat 12 engines while all CANAM 917/30's turbo 12 cylinders were V12 engines.
From Internet Sources
I've been inside a few days. Not to worry, just a little congestion. It's relatively mild outside for a Canadian Fall day and very sunny. However - No Palm trees in sight, temperature cool, a hat and gloves are a good idea though.
